USB -> eMMC is now available.
The title says it all ... link
How would you install a OS on the eMMC using this? Can you skip the sd card completely? Would love a tutorial.
(11-22-2017, 05:53 AM)Tony32 Wrote: How would you install a OS on the eMMC using this? Can you skip the sd card completely? Would love a tutorial.
just plug in the eMMC in to the USB converter, plug the usb converter in your pc, use Pine64Installer to flash the eMMC Wink
Just DD as you normally would to SD
Thanks for the quick replies! I ordered the Rock64 today. I wonder if its possible to dual boot easily like with NOOBs.
When using the USB-eMMC with PINE64 Installer, should you use the "microSD" or the microSD to eMMC" images?
(02-13-2018, 03:49 PM)GeerGuy Wrote: When using the USB-eMMC with PINE64 Installer, should you use the "microSD" or the microSD to eMMC" images?
MicroSD
Thumbs Down
When I install my new 16GB eMMC into the USB adapter and plug into a USB port I get the following error message:
Location is not available
F:\ is not accessible
Incorrect function.
Using Windows 10.
The red LED is on.
Any ideas?
(02-17-2018, 01:33 AM)GeerGuy Wrote: When I install my new 16GB eMMC into the USB adapter and plug into a USB port I get the following error message:
Incorrect function.
Using Windows 10.
The red LED is on.
Any ideas?
if the eMMC module has not been formatted or format as EXT4, then need to reformat before able to file access under Windows OS environment.
[note] Mostly is EXT4 format due to factory always loaded Android OS for device functional testing.
I used a Linux computer and it worked fine, Thanks
Is it possible to use the USB-eMMC Adapter in Windows?
Even after programming it once with a Linux computer, it still does not show up in Windows.
Possibly Related Threads...
  Receiving errors about eMMC (?) acasta 11 2,131 09-24-2019, 10:26 PM
Last Post: ridgarou
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 26,387 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 254 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 422 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 1,346 05-06-2018, 05:41 PM
Last Post: pfeerick
  [SOLVED] stuck at emmc dr_dre 10 1,952 04-29-2018, 05:10 PM
Last Post: pfeerick
  eMMC errors MrFawlty 8 1,015 04-02-2018, 09:33 PM
  eMMC angelscream09 6 986 03-17-2018, 02:08 PM
Last Post: KeithJohnAlger
  USB -> eMMC adapter coming soon Luke 7 1,161 02-09-2018, 04:46 AM
Last Post: xalius
  Unable to flash Android TV on eMMC: rkflashtool error fbossi 3 1,017 02-02-2018, 08:37 AM
Last Post: dannyboyw
