usb boot pinebook?
hello,
i know that the pinebook64 dosen't have a bootloader, bout is there a way to  install or boot in to a live usb or micro sd card? any help is appreciated.
not sure what you mean by "into", but i'm pretty sure you cannot boot "from" a usb stick.
you CAN boot from an operating system image "burned" to a microSD.
(10-18-2017, 10:02 AM)BUBLOS Wrote: hello,
atm you cannot boot a usb stick directly.  You may boot an SD card with a valid Arm image for the A64/Pinebook.  For instance, I have xenial-mate on my eMMC ( internal ) and I utilize xenial-i3 from my SD cards.  The SD card slot (if active) has boot priority.
You may boot 'from' eMMC or SD card and then 'run' the /rootfs from a usb stick,  or SSD; HDD;  what-have-you;  however,  the usb stick may not yet be used to boot-up, and of course live boot sticks for x86 will not work-- this is Arm for crying out loud.
Thank you so much for your answer, i still have a lot to learn about "ARM" PC and the pinebook Big Grin
  DietPi OS for Pinebook MichaIng 3 5,334 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,720 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 878 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 678 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,563 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,209 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,823 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,219 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,796 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,788 12-25-2020, 04:40 PM
Last Post: ford442
