RockBox
(10-21-2017, 12:37 PM)Wizzard Wrote: I just like that RockBox case. Would it be possible to upgrade the RAM and eMMC in that box? Or is it possible to buy that case alone?
Nope, its not a Rock64 in there - its a custom PCB.
Anyway, I am looking for some similar device for playing some video on my TV and this looks fine. I only need something that runs Spotify, Youtube and something like ShowBox/Popcorn Time, I guess this device can handle it, right?
(10-25-2017, 08:07 AM)Wizzard Wrote: Anyway, I am looking for some similar device for playing some video on my TV and this looks fine. I only need something that runs Spotify, Youtube and something like ShowBox/Popcorn Time, I guess this device can handle it, right?
I've tested the following and had a good experience:
  • Youtube
  • Kodi
  • RKMC
  • VLC
  • Plex
  • Netflix
(10-25-2017, 08:36 AM)Luke Wrote: I've tested the following and had a good experience:
  • Youtube
  • Kodi
  • RKMC
  • VLC
  • Plex
  • Netflix
Thank you, can you please also test Spotify a Showbox? :Smile Thx
  • Youtube
  • Kodi
  • RKMC
  • VLC
  • Plex
  • Netflix
Yea, will update the post once I do tonight.
I think Spotify should not be a problem. ShowBox too, although it is not in play store, I install it from apkmirror.
(10-25-2017, 02:56 PM)Wizzard Wrote: I think Spotify should not be a problem. ShowBox too, although it is not in play store, I install it from apkmirror.
Spotify works fine and so does ShowBox. That said ShowBox sometimes gives me 'the app has stopped responding' - but I just click wait and it works. Edit: only happens after selecting a movie - as it starts to play. There is a new OS firmware for the RockBox (released today) which I haven't tested and wont test.
Thank you very much, so it seems that RockBox is a good choice for that money.
edit: How long it took to arrive after order?
#19
After I ordered it I found similar solution that is even available in my country for similar price - http://venztech.com/v10/
I wonder what is the difference between these devices. Maybe RockBox has better support? The hardware seems very similar.
#20
(10-26-2017, 08:08 AM)Wizzard Wrote: After I ordered it I found similar solution that is even available in my country for similar price - http://venztech.com/v10/
The S905 is a similar SoC. The RockBox does have better support because a lot of the OpenSource stuff we do here will trickle down to the RockBox.
Checkout my post over at Popcorn Hour
  Rockbox firmware Wizzard 0 1,152 11-21-2021, 12:47 PM
Last Post: Wizzard
