My PINE64A won't boot
Just got a PINE64A 2G and weird enough is a Rev. B board made on 2016-03-21 Sad . I thought Rev. C was out  anyway, I wanted to have the openHAB running on this SBC.
Tried booting openhabianpine64-xenial-201706161506-git7ff273e-crcadda6dbb.img with Ethernet and without no difference the boot process freezes
2016-02-11_16:28:17_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2016-02-11_16:28:17_UTC [openHABian] If you see this message more than once, something went wrong!
2016-02-11_16:28:17_UTC [openHABian] Storing configuration... OK
2016-02-11_16:28:17_UTC [openHABian] Changing default username and password... SKIPPED
2016-02-11_16:28:17_UTC [openHABian] Setting up Wifi connection... SKIPPED
2016-02-11_16:28:17_UTC [openHABian] Ensuring network connectivity... 2017-10-07_17:47:56_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-10-07_17:47:56_UTC [openHABian] If you see this message more than once, something went wrong!
2017-10-07_17:47:56_UTC [openHABian] Storing configuration... OK
2017-10-07_17:47:56_UTC [openHABian] Changing default username and password... SKIPPED
2017-10-07_17:47:56_UTC [openHABian] Setting up Wifi connection... SKIPPED
2017-10-07_17:47:56_UTC [openHABian] Ensuring network connectivity...
2017-10-07_17:49:37_UTC [openHABian] Network unreachable, can't continue. Please reboot and let me try again.
2017-10-07_17:49:37_UTC [openHABian] Initial setup exiting with an error.
2017-10-07_17:43:04_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-10-07_17:43:04_UTC [openHABian] If you see this message more than once, something went wrong!
2017-10-07_17:43:04_UTC [openHABian] Storing configuration... OK
2017-10-07_17:43:04_UTC [openHABian] Changing default username and password... SKIPPED
2017-10-07_17:43:04_UTC [openHABian] Setting up Wifi connection... SKIPPED
2017-10-07_17:43:04_UTC [openHABian] Ensuring network connectivity...
Have a PSU that provides 5.2V and a Class 10 microSD card... Not sure what else I'm missing.
Any relevant hint is much appreciated.
cori
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,128 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,567 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,547 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,686 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,042 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,215 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,135 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,358 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,443 03-18-2020, 09:42 AM
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 2,327 09-03-2019, 11:57 PM
Last Post: hbaxmann
