LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
#21
Once again, thanks for the build. Just got back and had a chance to try stuff out.
Here are some issues I encountered:
1) On first boot airplay starts (plays an infinitely long file).
2) Mounting SMB by browsing gives me one of two errors:
* File Exists
* No Such Directory
(adding manually by entering IP works fine)
3) Plex plugin doesn't work
4) Amazon and Netflix install fine but give me the same error when trying to play:
*One or more items failed to play. Check log for more information.
I looked though the log - didn't see any errors.
Will keep on testing.
Just ordered my R64 yesterday and planning to try this build when it arrives. Still fairly new to the scene and excited to see how this performs against my RPI3. Has anyone using this build tried adding emulation yet? I love retroarch on my pi and plan to fiddle with trying to get that working on this platform as well. I also plan to try the Netflix and Chromium addon. Any experience or feedback from the group would be appreciated. I'll be sure to update with my experiences.
(11-13-2017, 11:38 AM)Mrfixit2001 Wrote: Just ordered my R64 yesterday and planning to try this build when it arrives. Still fairly new to the scene and excited to see how this performs against my RPI3. Has anyone using this build tried adding emulation yet? I love retroarch on my pi and plan to fiddle with trying to get that working on this platform as well. I also plan to try the Netflix and Chromium addon. Any experience or feedback from the group would be appreciated. I'll be sure to update with my experiences.
The performance is considerably higher than RPI 3 - in terms of computation. Then obviously storage and networking performance blow the RPI 3 out of the water  (USB 3.0 / GbE)  The Mali 450 is on par with VC4 - they are both low power/ spec.
As for emulation, there is a proper Lakka image that was just released (do keep in mind the R64 is a new product) and an early alpha of RetroPie. I saw that you can install emulators in LibreElec too - but didn't try that. If you like Retroarch then I'm sure you'll be pleased with Lakka - for a first image on this platform its very polished.
(11-13-2017, 04:25 AM)Luke Wrote: Once again, thanks for the build. Just got back and had a chance to try stuff out.
* File Exists
* No Such Directory
Thanks for the feedback. Just quick to mention your 4.) issue. That normally happens if you don't have widevine installed but you can provide a log.
The 2.) issue is also known to a SMB update and some recent changes in Windows 7/10:
https://libreelec.tv/2017/08/libreelec-k...-1-0-beta/
3.) This is probably due to Kodi 18 still being alpha. Most Addon developers don't update their code until Kodi reaches RC status. Emby is another example, but there are community driven updates. Other than that I'd recommend if you are using Plex to try kwiboo's openPHT (it that exists already)
Also I have subscribed to this Thread a couple of times but it always unsubscribes so I don't receive any email notifications on new replies. So please don't think that I've forgotten about this thread.
I'm preparing a quick update on this build. Remember this is still a pre alpha development build.
(11-11-2017, 06:20 PM)DominicP Wrote:
(11-10-2017, 04:25 AM)Raybuntu Wrote:
(11-10-2017, 03:02 AM)Luke Wrote:
(11-10-2017, 02:07 AM)Raybuntu Wrote: https://github.com/Raybuntu/LibreELEC.tv.../rb-leia15
Nice Smile Compatible with the RockBox or just the Rock64 ?
That build will only work on Rock64. I haven't had a time to unpack my Rockbox yet.
Also I had to revert an u-boot commit by kwibbo otherwise it wouldn't boot for me on Rock64 from SD card. I have no emmc to test so it might be possible that it fails to boot from emmc.
I have tested HW decoding, Netflix, Amazon VOD and Dazn. Netflix is not that smooth 720p and up yet.
eMMC boots successfully.
UK HDTV poor decoding.
UK SDTV decoding is fine.
UK broadcast is mpeg2? mpeg2 is currently not HW decoded only SW that's why the performance is bad on HDTV.
Raybuntu, many thanks.
With regard to Netflix/Amazon I just followed your instructions and installed the addons:
curl -Ls http://nmacleod.com/public/libreelec/getwidevine.sh | bash
Fully understand that its an alpha - just offering feedback Smile
(11-14-2017, 05:26 AM)Luke Wrote: Raybuntu, many thanks.
If it still doesn't work please attach a Kodi debug log and I'll have a look. Are you using a VPN by any chance? That might be causing issues as well.
pastebinit /storage/.kodi/temp/kodi.log
Not using a VPN. Will post tonight (GMT time) when I get home.
Managed to get to it before leaving - here is the log
(11-14-2017, 07:57 AM)Luke Wrote: Managed to get to it before leaving - here is the log
Thanks. I've forwarded your log to the NF addon developers. And you can't stream from Amazon either?
EDIT: Try to logout in the Addon settings first then ssh in your box:
rm /storage/.kodi/userdata/addon_data/service.msl/*
reboot
Once rebooted log in to NF again providing your Login data. Try to play something.
reboot
Ok, tried that - doesn't make a difference.
Here is the amazon log. Trailers on Amazon play however - also Amazon is in German, sometimes tells me 'this content is not available in your country'.
  Libreelec nfs shares nberg@xs4all.nl 0 658 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 1,275 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,739 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,610 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,233 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,048 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,055 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,631 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,007 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,113 11-16-2019, 12:17 PM
Last Post: dkebler
