Armbian - Xenial Desktop (Pinebook)
For release notes, please visit Armbian Website.
Armbian - Xenial Desktop (Pinebook SDCard) 5.32
- THIS IS FOR SDCard BOOT!!!
- MD5 (XZ file): 4d5446a705aa40aeaee03d14971b32ca
Anyone try this out yet? What's the performance like vs ayufan's Ubuntu images?
(07-27-2017, 04:04 AM)jordanjay29 Wrote: Anyone try this out yet? What's the performance like vs ayufan's Ubuntu images?
Haven't tried the newer images yet, but I did try the armbian build some 2 months ago; I felt that the XFCE ran a tad bit faster than mate. I imagine the current image itself has fewer functioning features (as well as experimental pre-release features) than ayufan's builds since Igor is currently away from the lab.
What is the difference between Armbian and Ayufan's Ubuntu? Different kernel but the same packages and repositories?
If they're using the XFCE WM, it will be less memory hungry than the Ubuntu Mate image is, but other than that, one thing to consider is the the Armbian images for the pinebook are still WIP (WorkInProgress), so they're not considered the 'release' grade of other Armbian images yet.
(07-27-2017, 06:00 AM)Wizzard Wrote: What is the difference between Armbian and Ayufan's Ubuntu? Different kernel but the same packages and repositories?
kernel is the same.
kernel is the same.
So the packages and repositories are different? Does it have also different DE, not only XFCE?
armbian devs spent time assuring that the packages they do have work together most of the time as a cohesive unit. you can install any desktop you want if you want to spend the time. quite a few of the armbian devs use headless enviroments.
First impression: it seems pretty quick and mpv seems to play 1080p full screen just fine Smile   but it tested it very briefly   Big Grin
(07-29-2017, 06:56 AM)rookieone Wrote: First impression: it seems pretty quick and mpv seems to play 1080p full screen just fine Smile   but it tested it very briefly   Big Grin
Still using Armbian on the Pinebook and I like it quite a lot! Smile
Have been applying some of the tweaks found on the forum, and also removed nodm and installed lightdm.
Pretty happy with this as user! Smile
  Reset User or Factory Reset PineBook Linux 11.6" pittman64 0 16 Yesterday, 03:52 PM
Last Post: pittman64
  Pinebook is going the way of Betamax? trigger 9 1,046 06-21-2020, 03:08 PM
Last Post: secristr
  Pinebook Pro (i3 WM): Confirm Shutdown on Power Button etothepii 2 163 06-07-2020, 11:18 AM
Last Post: xmixahlx
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 10 1,003 06-04-2020, 11:31 PM
Last Post: KRT
Information Manjaro ARM for Pinebook erchache2000 75 9,922 05-10-2020, 02:06 PM
Last Post: telle
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 1,542 04-27-2020, 06:27 AM
  Kali Linux for the Pinebook Luke 1 441 03-03-2020, 05:01 AM
Last Post: e-minguez
  Anyway to run Teamviewer for ARM/Pinebook? Ekkaia 8 3,747 01-16-2020, 08:51 PM
Last Post: dhosh
  Pinebook Wlan Driver does not work properly matze79 2 286 12-15-2019, 02:50 AM
Last Post: matze79
  Q4OS for PINEBOOK q4osteam 89 32,060 11-12-2019, 09:17 PM
Last Post: ac8dg
