Would HDMI screen for Raspberry PI work?
I have the Pinea64 4GB with the LCD screen. Unfortunately, Ubuntu doens't work with LCD, so I'm wondering if I purchase a HDMI LCD screen for the raspberry pi, would this work with the Pine??
(07-23-2017, 06:39 AM)dhewko Wrote: I have the Pinea64 4GB with the LCD screen. Unfortunately, Ubuntu doens't work with LCD, so I'm wondering if I purchase a HDMI LCD screen for the raspberry pi, would this work with the Pine??
PineA64 does not come in 4GB.  It works with the LCD but you have to set the variable in uEnv.txt to switch from hdmi to LCD.  If you want to use LCD, try the armbian build;  but also, you will need to set the variable to switch from hdmi to LCD mode.   A small hdmi LCD screen should work with the PineA64, but will not have touch, and should support 720p60 or 1080p60;   another option is to use a DVI monitor 1366x768 and use the hdmi--->vga adapter from the pine store.
Sad HDMI to DVI Color issues? leatherlips 5 19,973 10-09-2017, 05:57 AM
Last Post: Luke
Exclamation HDMI 1024 x 600 mus1c 4 8,566 01-09-2017, 07:30 AM
Last Post: mus1c
  HDMI-DVI aminhb 11 23,802 01-08-2017, 10:52 AM
Last Post: Luke
  HDMI issues rahlquist 35 61,280 12-24-2016, 02:20 AM
Last Post: sboyce
  Monitor no output (through HDMI to DVI adaptor) gam01hr 10 20,279 11-15-2016, 01:46 PM
Last Post: Armbian User
  HDMI CEC ayufan 15 25,608 09-08-2016, 10:24 AM
Last Post: ayufan
  HDMI to VGA adapter for Android PineA64 tech support setup MarkHaysHarris777 0 3,211 08-06-2016, 12:47 PM
Last Post: MarkHaysHarris777
  hdmi_group CEA or DMT hdmi group specify uEnv.txt MarkHaysHarris777 2 6,687 07-01-2016, 08:23 AM
  No CEC over HDMI? utdrmac 2 7,492 03-07-2016, 03:05 PM
Last Post: utdrmac
  HDMI 3D, ARC + Ethernet Channels? bigmacattack 4 15,101 01-29-2016, 06:29 PM
Last Post: StefanB
