First images with DRM and Mali support for A64
#61
I have problems with the Wi-Fi on this particular distribution. The system claims Wi-Fi is enabled and working but does not recognize any available networks (and adding the SSID and Passkey under network configuration does not make a difference). The system runs great for me otherwise. Video runs smoother than earlier ubuntu, and distro seems pretty responsive.
I have been using a Pi3 as a Squeezebox player, but I was hoping the Pine64 Wi-Fi might work better, It would be nice to get the wi-fi working and get squeezelite functional to test out if the Pine64 works better for a player...
#62
Now I tried to boot newly flashed 0.7.7 image and it really does not boot, the LED just blinks. When I removed the SD card, it booted from internal storage. Seems that new images are really a little strange.
#63
I was wondering what the practical use cases are now that we have Mali on Linux. Does anyone have an overview?
#64
(08-22-2017, 10:21 AM)rookieone Wrote: I was wondering what the practical use cases are now that we have Mali on Linux. Does anyone have an overview?
pretty much this Wink
#65
New goodie: https://github.com/ayufan-pine64/linux-b...tag/0.7.10. It fixed suspend/resume on non-sunxidrm drivers, making the 0.7.x actually useable as you can switch to Mali when needed.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#66
(08-23-2017, 12:00 PM)ayufan Wrote: New goodie: https://github.com/ayufan-pine64/linux-b...tag/0.7.10. It fixed suspend/resume on non-sunxidrm drivers, making the 0.7.x actually useable as you can switch to Mali when needed.
Hi, I have no success on booting images version 0.7.13, 0.7.14 with my pine64+(2GB) Using the image 0.7.12 and then updating seems to be without problems. The image I do use is: xenial-minimal-pine64-bspkernel-0.7.1*-***.img.xz
Someone experiencing same issue?
(09-19-2017, 01:24 AM)sportcanon Wrote: Hi, I have no success on booting images version 0.7.13, 0.7.14 with my pine64+(2GB) Using the image 0.7.12 and then updating seems to be without problems. The image I do use is: xenial-minimal-pine64-bspkernel-0.7.1*-***.img.xz
Just small correction - updating to higher then 0.7.12 also causes no booting to system. Previously I was in fact downgrading because I did not specify version.
#67
Thanks. I will verify that later. We had some troubles and tried some fixes for eMMC module.
Releases:
Buy me a Beer
#68
Been a while since I've been on these boards. Still have my A64 2GB, Gonna have to give this a try..... something tells me I'm going to owe Ayunfan and Lenny a beer Wink
#69
Hello Ayufan!
Its been more than 2 months since the last update. Is the development of these images dead?
We are waiting for a stable image with DRM and Mali support for Pine64.
Thank you.
#70
Good news, Allwinner BU3 just release A64 MALI-400 64 bit Wayland driver to Pine64. Here is the link: http://wiki.pine64.org/index.php/Mali_Dr...bit_driver
  Official Debian support! Luke 84 128,119 03-15-2024, 02:40 AM
Last Post: grobbs
  official support for aarch64 in OpenArena Opvolger 0 1,490 03-24-2022, 02:23 PM
Last Post: Opvolger
  Fedora 32 Release, improved support for Rock(Pro)64 Tharadash 2 5,774 05-05-2020, 08:37 AM
Last Post: zer0sig
  Kickstarter: Allwinner VPU support in the official Linux kernel xalius 8 14,624 10-03-2019, 03:03 AM
Last Post: bunkerWHz
