Rock64 as a retro-gaming console: early impressions
#31
(01-19-2018, 02:03 AM)Luke Wrote:
(01-18-2018, 04:51 PM)Danielsan Wrote: Just for curiosity is R64 able to handle Dreamcast and GameCube emulation?
Thanks!
Nope. You'd need a rk3399 box for Dreamcast and an Nvidia shield for smooth(ish) GC emulation.
Thanks again, I saw that for rk3399 and the Nvidia Shield we are in another range of price and I am not interested about that, I am fine with my Rock64. I look forward to have the R64 in my hands, eventually I bought a 128gb sd card.
#32
Hi guys,
I got my R64-64gb and I flashed Lakka on a Samsung EVO 128gb sd card.
Flashing and installation were fine however I did some tests and those weren't so exciting.
As first thing Lakka goes freeze for a couple of minutes quite often, with jut the ui as well with the emulation.
The Nintendo64 emulation with Paralleli was quite laggy, many slow downs and freeze, audio always slow down, minor graphical issues. I saw a PI3 with Recalbox doing much better than mine first attempt.
Probably there are some settings that I can tweaks to obtain better performance if anyone knows about these please let me know.
Thanks in advance,
D.
#33
Pardon me to return to the same argument so many times but I am still working to get good performance.
Reading your post again I just noticed that you were using Android instead of Lakka in your test. Regarding the emulation on "Android vs Lakka" I made some questions on the Lakka forum and for the experts Retroarch plays nicer on Linux instead of Android, however I didn't get any of your goals even if I bought the 4GB version.
16-bit consoles with Lakka play nice but without shaders so I am using a simple overlay; N64 play awful with several issues, as you wrote best option is to use Mupen64plus instead of Parallel but the former isn't available on Lakka. PS1 emulation plays with a lot of issues, it drops frames constantly so the animation is spurty and the games are thus unplayable.
I would like to try the emulation through the Ayufan Android image so I would like to new if, apart Mupen, did you make your test through Retroarch or with each emulators separately?
Thanks!
#34
Hey. I suggest you give this a rest for a few months. We've spoken to RecalBox guys and we'll be getting support for the Rock64. The issue, as I understand, is that Lakka currently do not use SDL; the RecalBox build will use kms instead of fbdev and SDL 2 +. This will, among other things, improve the situation when using overlays and shaders. This work will surely, in time, also find its way into Lakka and other retro-gaming distributions.
Do also keep in mind the difference in time that the RPI (3) had for development and the Rock64 had.
Have you tried emulation on Android ?
[edit] Answering your question; take a look at this thread if you want to build your own RetroPie image.
#35
I will follow your suggestion and looking forward to Recalbox! Wink
#36
(02-20-2018, 01:04 PM)Luke Wrote: Hey. I suggest you give this a rest for a few months. We've spoken to RecalBox guys and we'll be getting support for the Rock64. The issue, as I understand, is that Lakka currently do not use SDL; the RecalBox build will use kms instead of fbdev and SDL 2 +. This will, among other things, improve the situation when using overlays and shaders. This work will surely, in time, also find its way into Lakka and other retro-gaming distributions.
Woot woot! Great news! Can't wait. Is there a thread or some kind of blog to follow the progress?
#37
Are you asking about RecalBox? Once the devs get their gear perhaps they'll open up a thread (or I will on their forum). Otherwise I am sure you'll be able to track the progress on their git.
#38
I have never seen anyone working on any Recalbox porting, I don't believe there is anyone working on it. Unfortunately Lakka is truly buggy, I am going to try if the emulation is better through Android TV.
#39
(04-03-2018, 09:05 PM)Danielsan Wrote: I have never seen anyone working on any Recalbox porting, I don't believe there is anyone working on it. Unfortunately Lakka is truly buggy, I am going to try if the emulation is better through Android TV.
i use the regular root android. retroarch and kodi (rkmc) together offer a great 4k mediacenter and a great retrostation.
#40
Then you are clearly not in #Recalbox on freenode.
  Pine Rock64 eMMC lifespan moonspell79 3 284 08-19-2021, 06:46 PM
Last Post: bcnaz
  Rock64 No Audio - Solved wbecks 12 16,792 08-13-2021, 01:23 PM
Last Post: blakeadam
Question Hardware issues with Rock64 grobbs 11 2,416 07-24-2021, 10:23 AM
Last Post: robinkyle11
  Trustzone support for Rock64 capablegh 1 284 07-17-2021, 10:15 AM
Last Post: capablegh
  Python GPIO Library for the Rock64 (R64.GPIO) Leapo 37 40,518 07-02-2021, 03:20 PM
Last Post: klausfelix
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 254 07-02-2021, 03:13 PM
Information Serial Console for the Rock64 MarkHaysHarris777 33 33,328 06-24-2021, 12:24 PM
Last Post: mikeklien
  lost eletronic component rock64 marvin1986 1 518 06-01-2021, 06:27 PM
Last Post: 8bit
Shocked Rock64 - Reboots after few minutes addezai 2 737 04-22-2021, 07:03 PM
Last Post: addezai
  Rock64 Long Term stability ramprasad 4 2,343 03-16-2021, 07:23 PM
Last Post: Rocklobster
