Performance question - Rock64 vs A64+ vs RPi 3
I am a happy user of of an A64+ that is serving as a Linux server in my basement, and it has worked flawlessly with Armbian and Debian before that.
Anyway, Owncloud is a bit slow on the Pine and I am considering upgrading to a Rock64. Does anyone have a sense of how the performance of the 4GB board would compare to my 2GB A64? As an added question, any sense of how the Rock64 would compare to a RPi 3 performance wise focused on the Linux server use case?
Thank you!
JL
Sent from my XT1254 using Tapatalk
(07-08-2017, 02:48 PM)jl_678 Wrote: Hi,
Thank you!
JL
Are you asking specifically as a server ? With eMMC and USB 3.0 (and more RAM) likely considerably better for file-serving. My early pre-production unit doesn't have a functioning USB 3.0 but I am very much looking forward to trying out OMV (the img is already available) with a production R64 to compare against my Pine64 running OMV.
Thank you!
JL
Hi, yes primarily as a Linux server using eMMC. Webserving would be the primary use case.
Part of the reason I ask is that the article below suggests that the Rock64 uses the same cpu as the RPi 3 and thus that the performance will be similar. This seems odd to me.
https://www.extremetech.com/computing/25...10-support
Thank you!
JL
As Luke already mentioned, eMMC, USB3, and more RAM would definitely improve performance for moving data around.
But if your issue is that the CPU is at full load and struggling, you won't find much gain to the R64 since the CPU cores are practically the same (despite slightly higher clock speed).
The Rock64 will blow the RPi3 out of the water;  hands down , no contest;  the bottle neck hub on the RPi is not present on the Rock64, the Rock64 has two PHY, one Gbe, usb3.0 and the processor is 'better'  meaning faster and more responsive-- seriously , no contest.
Will it blow an A64+ out of the water too? (A 4GB Rock64 acting as a Linux server that is.)
(07-09-2017, 09:28 AM)jl_678 Wrote: Will it blow an A64+ out of the water too? (A 4GB Rock64 acting as a Linux server that is.)
The A64+ and a Pi3 are more or less equal (except in terms of Ethernet, where A64 wins big time).
So in terms of data throughput, yes it will.
In my opinion, yes.  But, that depends how you setup your server.  Because your SDD (or HDD) can be attached via usb3.0 , and because the Rock64 is about 10-15 % faster.  Its a more efficient SoC.
(no promises, and no quotes)
Tongue
Thank you everyone. Let me summarize what I read.
Why Rock64 is faster than RPi3
Slightly faster cpu
eMMC storage for faster access
No ethernet/USB bottleneck
USB 3.0
Up to 4GB of RAM vs 1GB for RPi
Why Rock64 is faster than A64+
Slightly faster cpu
USB 3.0
Up to 4GB RAM vs 2GB for A64+
Thank you,
JL
(07-09-2017, 07:41 PM)jl_678 Wrote: Hi,
Slightly faster cpu
USB 3.0
Slightly faster cpu
USB 3.0
Thank you,
JL
This is 100% correct. Smile
  Rock64 v2.0 u-boot SPI issues ju0n 0 529 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,855 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 27,402 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 16,235 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 18,047 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,617 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,550 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,612 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,897 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,751 11-28-2022, 02:18 PM
Last Post: Macgyver
