Bliss OS (Pinebook) 20170919 [Oct 13] | Bliss OS (PINE A64(+)) 20170919 [Oct 13] | Linux Images (ROCK64) 0.5.10-118 [Oct 2] | Android Images (ROCK64) 0.3.4-86 [Oct 2] | Android 6.0.1 (PINE A64-LTS / SOPINE) 20170726 [Sep 29] | Android 7.1 (Pinebook) 0.3.10-66 [Sep 19] | Android 7.1 (PINE A64(+)) 0.3.10-66 [Sep 19] | Android 7.1 (SOPINE) 0.3.10-66 [Sep 19] | PINE64 Installer v2.0.0-beta.3 [Sep 12]
Getting Started | Visit the WIKI | IRC Logs | Forum Rules/Policy
SMplayer tweaks
This is a short tutorial on tweaking SMplayer to perform at its optimum. You can expect smooth 1080p playback of most formats that VDPAU supports using these settings.
Open SMplayer and press Ctrl+p
Under general -> video
  • make sure to have vdpau as output driver
  • toggle Double Buffering
Under performance
  • toggle Allow Framedrop
  • Set treads for decoding to 4
  • Set loop filter to enable
That's it. Granted you have a supported video format file, it should play back perfectly fine in 720p and 1080p.
  If you manage to click this link you'll join in the IRC channel
(07-04-2017, 10:38 AM)Luke Wrote: This is a short tutorial on tweaking SMplayer to perform at its optimum. You can expect smooth 1080p playback of most formats that VDPAU supports using these settings.
Under performance
Thanks! Works for me!  Big Grin
