Bricked Pinebook?
(06-01-2017, 01:16 PM)CaptainZalo Wrote:
(06-01-2017, 09:15 AM)Luke Wrote: Guidol, yea me too.
Anyways, CaptainZalo why not just boot up from SD and then format the eMMC (it mounts on boot) ? See if that gives you any errors. If it doesn't then try reflashing eMMC
edit: Or try put it into FEL (using ayufans boot-tools) and reformat eMMC
I ordered an eMMC-to-µSD adapter. I'll need it for one of my other projects anyway. The pinebook is happily running android 7.1 at the moment, and my (3 year old) son is hogging it.
Yes, other than a dev device, its also great fun for kids Wink
(06-01-2017, 01:16 PM)CaptainZalo Wrote: I ordered an eMMC-to-µSD adapter. I'll need it for one of my other projects anyway. The pinebook is happily running android 7.1 at the moment, and my (3 year old) son is hogging it.
Please let us know how you go with that... will be nice to know if that is a compatible adapter or not Wink I do remember some discussion about the hardkernel adaper before, but I just can't remember if it was determined that it was or was not compatible.
haha  You need your own Dad...
Blush
(06-01-2017, 03:17 PM)Luke Wrote: edit: Or try put it into FEL (using ayufans boot-tools) and reformat eMMC
Uhm. How do I go about doing this?
I have about a kilogramme of µSD-cards lying around, and dedicating an 8gig one to such a recovery tool would be most valuable.
You don't need a SD card. You will however need to open the Pinebook to press a button on the inside (repeatedly). This is what you will need. Other than that I am not sure if you can do it from windows (think it will only work on nix - so linux or macos).
Again tho, I would just boot from SD card and try formating the eMMC (perhaps using the slow format option) first.
Following, intently !
Confused
Confused
It worked. Fdisk and remove all partitions then reformat worked. After that it installed Mate straight off the bat.
That buttonmashing is messy stuff. :-) A keypress combo or a reset-hole for a paperclip would be great for the next revision.
I got the other eMMC in the mail today. Since the onboard eMMC runs ubuntu mate and the sdcard runs android 7.1, I won't mess with it for a few days.
Confused
Very glad to hear. For the record, you can use scripts to update the kernel / uboot and packages to the newest (even pre-release) as per ayufan's instructions in his git. So no need to re-flash the eMMC per se in the future, unless something brand new comes along.
#19
The eMMC to microSD adapter arrived yesterday. It's a bit silly in way of design, so it won't work in the sd slot on the pinebook due to slidelock. But with a slight press, it initialized and mounted. I've tested two usb adapters too, and the adapter works well. I say go for it.
#20
(06-10-2017, 12:16 AM)CaptainZalo Wrote: The eMMC to microSD adapter arrived yesterday. It's a bit silly in way of design, so it won't work in the sd slot on the pinebook due to slidelock. But with a slight press, it initialized and mounted. I've tested two usb adapters too, and the adapter works well. I say go for it.
Great to hear! (and that you got the eMMC back up and running in the meantime as well). Can I just confirm that you got the super expensive hardkernel oneTongue  Big Grin
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 4 1,711 04-15-2021, 12:30 PM
Last Post: sebboh
  Pinebook Users are a nobody leperotero 7 1,955 01-30-2021, 03:32 PM
  new pinebook help ron_burgundy 5 1,961 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 2,575 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 933 11-16-2020, 01:25 AM
Last Post: jay3gg
  Pinebook doesn't charge anymore Reinoud 4 2,984 11-15-2020, 10:26 PM
Last Post: pagesix1536
  Pinebook 14" smashed screen. frank-zappa 4 2,466 10-18-2020, 09:24 AM
Last Post: frank-zappa
Wink Usuarios pinebook español luis 3 2,696 09-10-2020, 09:41 AM
Last Post: leperotero
Smile Pinebook Wallpapers - submissions please! Luke 29 19,650 08-07-2020, 02:45 PM
Last Post: natasha
Sad Disappointment with the Pinebook leperotero 7 5,174 07-01-2020, 11:26 PM
Last Post: sujunmin
