[April 06] Volumio (2.390-2018-03-27) ROCK64 | [April 06] Q4OS (2.4-r3) PINE A64(+) Pinebook | [Jan 06] Arch Linux (20171225-1) PINE A64(+) Pinebook A64-LTS/SOPINE | [Jan 04] Linux (0.5.15-136) ROCK64 | [Jan 04] Android (20171204) ROCK64 | [Dec 22] Stretch Mate (0.5.15-136-20171222) ROCK64 | [Dec 21] openHAB 2 (v1.4) PINE A64(+)
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
[SOLVED]Problem Compiling modules: Recipe | kernel-headers not found
Greetings
I found a little problem and thanks to the indications of @longsleep I was able to solve this problem.
I am writing this post in case someone stepped with this problem too.
The Issue
I was trying to compile some module for the kernel but I was not able to
because make complained about not finding the recipe.
The issue was produced because /lib/modules/(VERSION)/build was missing
The Soultion
The quickfix was to create a symlink called /lib/modules/(VERSION)/build  to /usr/src/linux-headers(VERSION)
The origin of the bug is that the pine64_update_kernel.sh is not updated.
You can find the last version in longsleep github
Extra information
I am using the image Debian Base (3.10.102 BSP 2) Jul 17 2016
from https://www.pine64.pro/downloads/#Debian-Linux
I hope this may help someone
Possibly Related Threads...
  Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 258 78,450 03-24-2018, 08:34 PM
Last Post: KNERD
  dvb-usb-dib0700 module not found. Miguel Campos 2 141 12-02-2017, 06:05 AM
Last Post: Miguel Campos
  OMV base on Debian jessie Root Problem ayamy 3 282 09-03-2017, 09:21 PM
Question Debian Jessie with 4.x.y kernel and complete hardware support? Spark 2 1,138 04-24-2017, 09:56 PM
Last Post: Spark
  Adding a missing kernel module spz2k 8 922 01-10-2017, 06:22 AM
Last Post: xalius
  NIC not visible after kernel update xleon 1 496 11-15-2016, 05:23 PM
Last Post: xleon
  Synergy dependency problem S265 3 579 10-27-2016, 12:44 PM
Last Post: TidBits
  LCD Monitor resolution problem S265 2 942 09-21-2016, 05:19 AM
Last Post: S265
  Debian Jessie (4.7.0-rc1 Kernel) Images fire219 4 3,249 07-20-2016, 02:36 PM
Last Post: umiddelb
  i2c-bus kernel modules robertvaldimarsson 15 1,211 06-07-2016, 01:48 PM
Last Post: robertvaldimarsson
