CyanogenMod 13
(02-04-2016, 08:22 AM)Hahaburger Wrote: Weird, I almost changed nothing on that image. I've just added one kernel parameter and some sepolicies.
I also checked your sha256sum which is the same on my PC so download is OK.
I've prepared new boot image and changed kernel parameter:
https://drive.google.com/file/d/0B5NrIPX...sp=sharing
Trying again and writing down the steps (in order to catch any mistake).
1.
android_20160112.img (SHA256: c734b943a5f537b5bff7fbe9792ceb63e13f8258037d6082e5c570272f6b74e9)
sudo dd if=android_20160112.img of=/dev/sdc bs=16M
2.
boot.img (SHA256: 09bca0dde761b230417d33137b5ba9ebcd83c27ead2f3a250b9d6d7ce49ffc2d)
system.img (SHA256: 392320bbaae74af650e71c65ce62b737b3cfee193316204633889515be770134)
sudo dd if=boot.img of=/dev/sdc6 bs=16M
sudo dd if=system.img of=/dev/sdc7 bs=16M
Then, booted. Here is the log:
Connected.
HELLO! BOOT0 is starting!
boot0 commit : 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.1
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM zq value: 003b3bbb
DRAM single rank full DQ OK
DRAM size = 1024 MB
DRAM init ok
dram size =1024
card boot number = 0, boot0 copy = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 15423 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000fc000.
sum=15bc131f
src_sum=15bc131f
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x0000b400 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019c00 success
set arisc reset to de-assert state
Ready to disable icache.
K9=�    Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):2fe7b0a
NOTICE:  BL3-1: Built : 10:15:37, Jan 12 2016
NOTICE:  BL3-1 commit: 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x4a000000
INFO:    BL3-1: Next image spsr = 0x1d3
U-Boot 2014.07 (Jan 12 2016 - 10:15:41) Allwinner Technology
uboot commit : 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d
rsb: secure monitor exist
[      0.377]pmbus:   ready
[      0.380][ARISC] :arisc initialize
[      0.710][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc_para size:1a8
[SCP] :arisc version: [v0.1.76]
[SCP] :sunxi-arisc driver v1.10 is starting
[      0.838][ARISC] :sunxi-arisc driver startup succeeded
[      0.871]PMU: AXP81X
[      0.873]PMU: read AXP81X 84H=0xf2
[      0.877]PMU: write AXP81X 84H=0xf6
[      0.880]PMU: AXP81X found
bat_vol=337, ratio=100
[      0.887]PMU: dcdc2 1100
[      0.890]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
device_type = 3253, onoff=1
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1100, onoff=1
dcdc6_vol = 1100, onoff=1
aldo1_vol = 2800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dldo1_vol = 3300, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 3300, onoff=1
eldo1_vol = 1800, onoff=1
eldo2_vol = 1800, onoff=0
eldo3_vol = 1800, onoff=0
fldo1_vol = 1200, onoff=0
fldo2_vol = 1100, onoff=1
gpio0_vol = 3100, onoff=0
vbus not exist
no battery, limit to dc
run key detect
key pressed value=0x1
fel key not configed
key pressed value=0x2
key pressed value=0x3
time out
key not pressed anymore
no uart input
DRAM:  1008 MiB
fdt addr: 0x76eb70e0
Relocation Offset is: 35f09000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[     12.573]start
drv_disp_init
init_clocks: finish init_clocks.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
boot_disp.output_disp=0
boot_disp.output_type=3
boot_disp.output_type=10
fetch script data boot_disp.auto_hpd fail
disp0 device type(4) enable
attched ok, mgr0<-->device1, type=4, mode=10
[     12.945]end
workmode = 0,storage type = 1
[     12.949]MMC: 0
[mmc]: mmc driver ver 2015-07-29 14:10:00
SUNXI SD/MMC: 0
[mmc]: start mmc_calibrate_delay_unit, don't access device...
[mmc]: delay chain cal done, sample: 200(ps)
[mmc]: media type 0x0
[mmc]: ************Try SD card 0************
[mmc]: host caps: 0x27
[mmc]: MID 1b PSN 008541f6
[mmc]: PNM 00000 -- 0x30-30-30-30-30
[mmc]: PRV 1.0
[mmc]: MDT m-12 y-2011
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 4 bit
[mmc]: user capacity  : 15423 MB
[mmc]: ************SD/MMC 0 init OK!!!************
[mmc]: erase_grp_size      : 0x1WrBlk*0x200=0x200 Byte
[mmc]: secure_feature      : 0x0
[mmc]: secure_removal_type : 0x0
[     13.160]sunxi flash init ok
--------fastboot partitions--------
-total partitions:11-
-name-        -start-       -size-
bootloader  : 1000000       2000000
env         : 3000000       1000000
boot        : 4000000       1000000
system      : 5000000       60000000
misc        : 65000000      1000000
recovery    : 66000000      2000000
cache       : 68000000      30000000
metadata    : 98000000      1000000
private     : 99000000      1000000
alog        : 9a000000      5000000
UDISK       : 9f000000      0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 1
recovery key high 12, low 10
fastboot key high 6, low 4
misc partition found
to be run cmd=run setargs_mmc boot_normal
update dtb dram start
update dtb dram  end
** Unrecognized filesystem type **
load file(sn.txt) error
serial is: 241051900808142809cb
no battery exist
sunxi_bmp_logo_display
681774 bytes read in 36 ms (18.1 MiB/s)
bmp file buffer: 0x41000000, bmp_info.buffer: 47400000
fetch script data boot_disp.output_full fail
screen_id =0, screen_width =1920, screen_height =1080
frame buffer address 47400036
[     13.769]inter uboot shell
Hit any key to stop autoboot:  0
read partition: boot or recovery
[     14.602]sunxi flash read :offset 4000000, 16918757 bytes OK
Kernel load addr 0x41080000 size 10881 KiB
Kernel command line: enforcing=0
RAM disk load addr 0x42000000 size 4617 KiB
[     14.946]ready to boot
prepare for kernel
[mmc]: MMC Device 2 not found
[mmc]: mmc 2 not find, so not exit
Starting kernel ...
INFO:    BL3-1: Next image address = 0x41080000
INFO:    BL3-1: Next image spsr = 0x3c5
Which means it got stuck.
I then tried out an earlier boot.img
and here is the full log
Connected.
set pll start
set pll end
PMU: AXP81X
DRAM clk = 672 MHz
DRAM size = 1024 MB
DRAM init ok
dram size =1024
card no is 0
[mmc]: 50000000 Hz
[mmc]: 15423 MB
sdcard 0 init ok
sum=15bc131f
src_sum=15bc131f
boot0: Loading scp
[      0.376]pmbus:   ready
[      0.379][ARISC] :arisc initialize
[      0.871]PMU: AXP81X
bat_vol=412, ratio=100
vbus not exist
run key detect
time out
no uart input
DRAM:  1008 MiB
In:    serial
Out:   serial
Err:   serial
[     12.577]start
drv_disp_init
[     12.948]end
[     12.952]MMC: 0
SUNXI SD/MMC: 0
[mmc]: PRV 1.0
[     13.167]sunxi flash init ok
UDISK       : 9f000000      0
key 1
update dtb dram  end
no battery exist
[     13.776]inter uboot shell
[     14.608]sunxi flash read :offset 4000000, 16918757 bytes OK
[     14.955]ready to boot
prepare for kernel
Starting kernel ...
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65 (dogukan@dogukan-GE70-2OD) (gcc version 4.9.3 20150113 (prerelease) (Linaro GCC 4.9-2015.01-3) ) #3 SMP PREEMPT Wed Feb 3 14:42:22 EET 2016
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: sun50iw1p1
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] cma: CMA: reserved 356 MiB at 69c00000
[    0.000000] On node 0 totalpages: 258048
[    0.000000]   DMA zone: 3528 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 258048 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc028b84000 s20224 r8192 d20736 u49152
[    0.000000] pcpu-alloc: s20224 r8192 d20736 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 254520
[    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c28000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p7 init=/init partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:system@mmcblk0p7:misc@mmcblk0p8:recovery@mmcblk0p9:cache@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:alog@mmcblk0p13:UDISK@mmcblk0p1 cma=356M androidboot.serialno=241051900808142809cb androidboot.hardware=sun50iw1p1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 1008MB = 1008MB total
[    0.000000] Memory: 632476k/632476k available, 399716k reserved
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
[    0.000000]     vmemmap : 0xffffffbc00e38000 - 0xffffffbc01c00000   (    13 MB)
[    0.000000]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc03f000000   (  1008 MB)
[    0.000000]       .init : 0xffffffc0009e5000 - 0xffffffc000a68f00   (   528 kB)
[    0.000000]       .text : 0xffffffc000080000 - 0xffffffc0009e4624   (  9618 kB)
[    0.000000]       .data : 0xffffffc000a69000 - 0xffffffc000b20360   (   733 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] Console: colour dummy device 80x25
[   15.122118] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   15.132258] pid_max: default: 32768 minimum: 301
[   15.137201] Security Framework initialized
[   15.140807] SELinux:  Initializing.
[   15.144344] SELinux:  Starting in enforcing mode
[   15.148989] Mount-cache hash table entries: 256
[   15.155006] Initializing cgroup subsys debug
[   15.157333] Initializing cgroup subsys freezer
[   15.161857] ftrace: allocating 25189 entries in 99 pages
[   15.198312] CPU0: update cpu_power 1968128
[   15.198345] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   15.206289] virtual base = 0xffffff800000a000.
[   15.209204] gicd_base = 0xffffff800000c000.
[   15.213342] gicc_base = 0xffffff800000e000.
[   15.219485] CPU1: Booted secondary processor
[   15.219507] CPU1: update cpu_power 1968128
[   15.222110] CPU2: Booted secondary processor
[   15.222123] CPU2: update cpu_power 1968128
[   15.226229] CPU3: Booted secondary processor
[   15.226240] CPU3: update cpu_power 1968128
[   15.226324] Brought up 4 CPUs
[   15.248276] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   15.255641] devtmpfs: initialized
[   15.285191] atomic64 test passed
[   15.285214] pinctrl core: initialized pinctrl subsystem
[   15.299967] NET: Registered protocol family 16
[   15.300544] script_sysfs_init success
[   15.304657] dump_class_init,788, success
[   15.307599] vdso: 2 pages (1 code, 1 data) at base ffffffc000a71000
[   15.312393] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   15.320251] software IO TLB [mem 0x67c00000-0x68000000] (4MB) mapped at [ffffffc026c00000-ffffffc026ffffff]
[   15.329740] DMA: preallocated 256 KiB pool for atomic allocations
[   15.335355] axp81x_board_init: axp regl_devs num = 23
[   15.339820] pll_audio-set_default_rate=24576000 success!
[   15.344694] pll_video0-set_default_rate=297000000 success!
[   15.350158] pll_video1-set_default_rate=297000000 success!
[   15.355513] pll_de-set_default_rate=297000000 success!
[   15.361536] de-set_default_source=pll_de success!
[   15.365057] de-set_default_rate=297000000 success!
[   15.369806] tcon0-set_default_source=pll_mipi success!
[   15.374827] tcon1-set_default_source=pll_video0 success!
[   15.380279] hdmi-set_default_source=pll_video0 success!
[   15.388540] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   15.392223] [sun50iw1p1_pinctrl_probe][838]
[   15.398434] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   15.404925] sunxi hwspinlock vbase:0xffffff800005c000
[   15.425654] sunxi_chipid_probe,150: soc bin:0
[   15.480196] bio: create slab <bio-0> at 0
[   15.481229] pwm module init!
[   15.481707] sunxi_pwm pwm0.9: unable to map pwm registers
[   15.486732] sunxi_pwm: probe of pwm0.9 failed with error -22
[   15.496747] SCSI subsystem initialized
[   15.497761] usbcore: registered new interface driver usbfs
[   15.501483] usbcore: registered new interface driver hub
[   15.507096] usbcore: registered new device driver usb
[   15.513832] Linux video capture interface: v2.00
[   15.518041] [ARISC] :sunxi-arisc driver v1.10
[   15.539648] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   15.540571] Advanced Linux Sound Architecture Driver Initialized.
[   15.547309] Bluetooth: Core ver 2.16
[   15.549597] NET: Registered protocol family 31
[   15.553740] Bluetooth: HCI device and connection manager initialized
[   15.560004] Bluetooth: HCI socket layer initialized
[   15.564764] Bluetooth: L2CAP socket layer initialized
[   15.569748] Bluetooth: SCO socket layer initialized
[   15.575412] cfg80211: Calling CRDA to update world regulatory domain
[   15.581439] [pm]aw_pm_init!
[   15.583488] rtc physical base = 0x0000000001f00000 .
[   15.588420] np name = /soc@01c00000/rtc@01f00000.
[   15.593055] base = ffffff800006c100, len = 4.
[   15.597318] pmu name: pmu0 .
[   15.600176] pmu0_enable = 0x1.
[   15.603204] pmux_id = 0x6.
[   15.605933] pmux_twi_id = 0x1.
[   15.609002] pmux_twi_addr = 0x34.
[   15.612337] pmu name: pmu1 .
[   15.615191] Warning: can not find np for pmu1.
[   15.619817] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   15.625792] after inited: sys_mask config = 0x4a55.
[   15.630510] Warning: can not find np for dynamic_standby_para.
[   15.636411] [pm]valid
[   15.638507] [pm]valid
[   15.640725] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby.
[   15.650154] Switching to clocksource arch_sys_counter
[   15.695430] FS-Cache: Loaded
[   15.695969] CacheFiles: Loaded
[   15.721746] NET: Registered protocol family 2
[   15.723180] TCP established hash table entries: 8192 (order: 5, 131072 bytes)
[   15.727655] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[   15.734030] TCP: Hash tables configured (established 8192 bind 8192)
[   15.741163] TCP: reno registered
[   15.743262] UDP hash table entries: 512 (order: 2, 16384 bytes)
[   15.749092] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[   15.756087] NET: Registered protocol family 1
[   15.760474] Unpacking initramfs...
[   15.999565] Freeing initrd memory: 4616K (ffffffc001000000 - ffffffc001482000)
[   16.002928] lock super standby defaultly!
[   16.005051] lookup_scene_lock_name: new scene lock super_standby
[   16.010950] scene_lock_init name=super_standby
[   16.015279] scene_lock: super_standby, type 5, count 1
[   16.021557] audit: initializing netlink socket (disabled)
[   16.025664] type=2000 audit(0.820:1): initialized
[   16.034858] NTFS driver 2.1.30 [Flags: R/W].
[   16.035112] fuse init (API version 7.22)
[   16.039344] msgmni has been set to 1956
[   16.042083] SELinux:  Registering netfilter hooks
[   16.048623] NET: Registered protocol family 38
[   16.050980] io scheduler noop registered
[   16.054763] io scheduler deadline registered
[   16.059085] io scheduler cfq registered (default)
[   16.065522] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   16.069463] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   16.077282] console [ttyS0] enabled, bootconsole disabled
[   16.089485] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   16.101269] misc dump reg init
[   16.112321] loop: module loaded
[   16.116068] sunxi-bt bt.27: Missing bt_power.
[   16.120845] sunxi-bt bt.27: bt_power_name ((null))
[   16.126080] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   16.132205] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   16.140807] sunxi-bt bt.27: clk not config
[   16.145579] sunxi-bt bt.27: block state already is 1
[   16.151457] sunxi-wlan wlan.26: wlan_busnum (1)
[   16.156404] sunxi-wlan wlan.26: Missing wlan_power.
[   16.161741] sunxi-wlan wlan.26: wlan_power_name ((null))
[   16.167554] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   16.174041] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   16.183388] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   16.193017] sunxi-wlan wlan.26: clk not config
[   16.200911] tun: Universal TUN/TAP device driver, 1.6
[   16.206445] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   16.214272] WARNING: Get ephy clock is failed
[   16.220306] PPP generic driver version 2.4.2
[   16.225655] PPP BSD Compression module registered
[   16.230790] PPP Deflate Compression module registered
[   16.236325] PPP MPPE Compression module registered
[   16.241555] NET: Registered protocol family 24
[   16.246458] PPTP driver version 0.8.5
[   16.250713] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   16.258255] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   16.265560] usbcore: registered new interface driver usb-storage
[   16.272316] usbcore: registered new interface driver ums-alauda
[   16.278978] usbcore: registered new interface driver ums-cypress
[   16.285732] usbcore: registered new interface driver ums-datafab
[   16.292471] usbcore: registered new interface driver ums_eneub6250
[   16.299417] usbcore: registered new interface driver ums-freecom
[   16.306169] usbcore: registered new interface driver ums-isd200
[   16.312818] usbcore: registered new interface driver ums-jumpshot
[   16.319670] usbcore: registered new interface driver ums-karma
[   16.326248] usbcore: registered new interface driver ums-onetouch
[   16.333102] usbcore: registered new interface driver ums-realtek
[   16.339850] usbcore: registered new interface driver ums-sddr09
[   16.346510] usbcore: registered new interface driver ums-sddr55
[   16.353154] usbcore: registered new interface driver ums-usbat
[   16.360252] usbcore: registered new interface driver usbserial
[   16.366821] usbcore: registered new interface driver option
[   16.373083] usbserial: USB Serial support registered for GSM modem (1-port)
[   16.381859] mousedev: PS/2 mouse device common for all mice
[   16.388401] usbcore: registered new interface driver xpad
[   16.394498] usbcore: registered new interface driver usb_acecad
[   16.401150] usbcore: registered new interface driver aiptek
[   16.407451] usbcore: registered new interface driver gtco
[   16.413548] usbcore: registered new interface driver hanwang
[   16.419922] usbcore: registered new interface driver kbtab
[   16.426114] usbcore: registered new interface driver wacom
[   16.434205] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   16.441661] sunxi-rtc 1f00000.rtc: RTC enabled
[   16.447118] IR NEC protocol handler initialized
[   16.452075] IR RC5(x) protocol handler initialized
[   16.457304] IR RC6 protocol handler initialized
[   16.462256] IR JVC protocol handler initialized
[   16.467200] IR Sony protocol handler initialized
[   16.472246] IR RC5 (streamzap) protocol handler initialized
[   16.478329] IR SANYO protocol handler initialized
[   16.483469] IR MCE Keyboard/mouse protocol handler initialized
[   16.490279] Registered IR keymap rc_map_sunxi
[   16.496012] input: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0/input0
[   16.504320] rc0: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0
[   16.511871] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input1
[   16.522100] sunxi cedar version 0.1
[   16.526106] [cedar]: install start!!!
[   16.530184] ycy the get irq is 90
[   16.534431] ycy clk_bass_vir 0x18  is ffffff800009a018, the value:3006207
[   16.541855] ycy clk_bass_vir 0x13c  is ffffff800009a13c, the value:0
[   16.548793] ycy clk_bass_vir 0x64  is ffffff800009a064, the value:601810
[   16.556120] ycy clk_bass_vir 0x2c4  is ffffff800009a2c4, the value:601c10
[   16.563540] ycy clk_bass_vir 0x100  is ffffff800009a100, the value:0
[   16.570483] [cedar]: install end!!!
[   16.580653] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input2
[   16.604575] sunxi budget cooling probe start !
[   16.609474] CPU freq cooling register Success
[   16.614243] CPU hotplug cooling register Success
[   16.619645] CPU budget cooling register Success
[   16.625260] sunxi gpu cooling probe start !
[   16.629847] CPU gpu cooling register Success
[   16.634890] device-mapper: uevent: version 1.0.3
[   16.640478] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[   16.649926] Bluetooth: HCI UART driver ver 2.2
[   16.654778] Bluetooth: HCI H4 protocol initialized
[   16.660045] Bluetooth: HCI Three-wire UART (H5) protocol initialized
[   16.670114] cpuidle: using governor ladder
[   16.674584] cpuidle: using governor menu
[   16.679852] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.17 2015-6-16 10:35) Compiled in Jan 30 2016 at 21:06:32
[   16.692776] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   16.699443] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   16.706195] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   16.713343] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   16.719637] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   16.726483] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[   16.732446] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   16.743426] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   16.766824] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   16.796304] sunxi-mmc 1c0f000.sdmmc: base:0xffffff800009c000 irq:92
[   16.803693] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.17 2015-6-16 10:35) Compiled in Jan 30 2016 at 21:06:32
[   16.816573] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   16.823512] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   16.830571] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   16.837611] get() with no identifier
[   16.841509] get() with no identifier
[   16.845407] get() with no identifier
[   16.849328] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   16.855525] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   16.861799] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   16.868799] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   16.879762] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   16.895495] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   16.902958] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   16.904529] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   16.921020] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   16.924234] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000a4000 irq:93
[   16.941767] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   16.941894] hidraw: raw HID events driver (C) Jiri Kosina
[   16.953443] usbcore: registered new interface driver usbhid
[   16.953446] usbhid: USB HID core driver
[   16.954337] zram: Created 1 device(s) ...
[   16.974838] ashmem: initialized
[   16.975967] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   16.976779] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   16.977591] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   16.978403] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   16.979035] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   16.979086] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   16.981460] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   17.009940] mmc0: host does not support reading read-only switch. assuming write-enable.
[   17.011737] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   17.011792] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   17.011895] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   17.011918] mmc0: new high speed SDHC card at address b368
[   17.088244] logger: created 256K log 'log_main'
[   17.088743] mmcblk0: mmc0:b368 00000 15.0 GiB
[   17.091253]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 >
[   17.096229] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.097037] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.097053] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.099459] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.101275] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.102079] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.102883] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.103688] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.104492] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.105299] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.106103] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.106908] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.107713] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.107728] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.108563] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.108580] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   17.229567] logger: created 256K log 'log_events'
[   17.235024] logger: created 256K log 'log_radio'
[   17.240387] logger: created 256K log 'log_system'
[   17.255467] sunxi-codec-machine sound.6:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.265084] sunxi-codec-machine sound.6:  codec-aif2 <-> bb-dai mapping ok
[   17.273021] sunxi-codec-machine sound.6:  codec-aif2 <-> bb-dai mapping ok
[   17.280977] sunxi-codec-machine sound.6:  codec-aif3 <-> bb-dai mapping ok
[   17.291597] input: audiocodec sunxi Audio Jack as /devices/soc.0/sound.6/sound/card0/input3
[   17.302946] sndhdmi sound.7:  sndhdmi <-> 1c22800.daudio mapping ok
[   17.311518] u32 classifier
[   17.314472]     Actions configured
[   17.318199] Netfilter messages via NETLINK v0.30.
[   17.323430] nf_conntrack version 0.5.0 (7825 buckets, 31300 max)
[   17.330447] ctnetlink v0.93: registering with nfnetlink.
[   17.338161] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[   17.345763] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[   17.353308] xt_time: kernel timezone is -0000
[   17.358185] ipip: IPv4 over IPv4 tunneling driver
[   17.364297] gre: GRE over IPv4 demultiplexor driver
[   17.369632] ip_gre: GRE over IPv4 tunneling driver
[   17.377051] ip_tables: (C) 2000-2006 Netfilter Core Team
[   17.383256] arp_tables: (C) 2002 David S. Miller
[   17.388411] TCP: bic registered
[   17.391835] TCP: cubic registered
[   17.395441] TCP: westwood registered
[   17.399349] TCP: htcp registered
[   17.402867] Initializing XFRM netlink socket
[   17.407833] NET: Registered protocol family 10
[   17.415037] mip6: Mobile IPv6
[   17.418358] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   17.424663] sit: IPv6 over IPv4 tunneling driver
[   17.430958] NET: Registered protocol family 17
[   17.435886] NET: Registered protocol family 15
[   17.441222] Bluetooth: RFCOMM TTY layer initialized
[   17.446597] Bluetooth: RFCOMM socket layer initialized
[   17.452205] Bluetooth: RFCOMM ver 1.11
[   17.456295] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   17.462092] Bluetooth: BNEP filters: protocol multicast
[   17.467825] Bluetooth: BNEP socket layer initialized
[   17.473244] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   17.479736] Bluetooth: HIDP socket layer initialized
[   17.485758] Registering SWP/SWPB emulation handler
[   17.492930] get usb_serial_number success from boot command line
[   17.499724] init: failed to probe driver -19[   17.504770] sunxi-rtc 1f00000.rtc: setting system clock to 2010-01-01 00:00:12 UTC (1262304012)
[   17.515397] input: sunxi-ths as /devices/virtual/input/input4
[   17.522003] thermal thermal_zone0: failed to read out thermal zone 0
[   17.537004] ALSA device list:
[   17.540252]   #0: audiocodec
[   17.543391]   #1: sndhdmi
[   17.546844] Freeing unused kernel memory: 524K (ffffffc0009e5000 - ffffffc000a68000)
[   17.557609] init: init started!
[   17.570973] SELinux: 2048 avtab hash slots, 4929 rules.
[   17.582239] SELinux: 2048 avtab hash slots, 4929 rules.
[   17.587994] SELinux:  1 users, 2 roles, 531 types, 0 bools, 1 sens, 1024 cats
[   17.595844] SELinux:  87 classes, 4929 rules
[   17.603928] SELinux:  Completing initialization.
[   17.608973] SELinux:  Setting up existing superblocks.
[   17.614613] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.622417] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[   17.630511] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[   17.638912] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   17.646544] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.654457] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[   17.663329] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[   17.676407] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   17.683954] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   17.691466] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[   17.701378] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[   17.709489] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[   17.718119] SELinux: initialized (dev configfs, type configfs), not configured for labeling
[   17.727253] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.735166] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.933604] type=1403 audit(1262304012.930:2): policy loaded auid=4294967295 ses=4294967295
[   17.943459] init: (Initializing SELinux enforcing took 0.39s.)
[   17.956085] init: init second stage started!
[   18.013646] init: waitpid failed: No child processes
[   18.019341] init: (Loading properties from /default.prop took 0.00s.)
[   18.028435] init: (Parsing /init.environ.rc took 0.00s.)
[   18.034555] init: (Parsing /init.usb.rc took 0.00s.)
[   18.040662] init: (Parsing init.common.rc took 0.00s.)
[   18.046496] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   18.052963] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   18.059074] init: (Parsing /init.sun50iw1p1.rc took 0.02s.)
[   18.065554] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   18.071917] init: /init.zygote64_32.rc: 1: ignored duplicate definition of service 'zygote'
[   18.081073] init: /init.zygote64_32.rc: 10: ignored duplicate definition of service 'zygote_secondary'
[   18.091262] init: (Parsing /init.zygote64_32.rc took 0.02s.)
[   18.097595] init: (Parsing /init.trace.rc took 0.00s.)
[   18.103271] init: could not import file '/init.cm.rc' from '/init.rc'
[   18.110358] init: (Parsing /init.rc took 0.08s.)
[   18.115622] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[   18.126083] init: Starting service 'ueventd'...
[   18.131441] init: Waiting for /dev/.coldboot_done...
[   18.133671] ueventd: ueventd started!
[   18.533222] ueventd: Coldboot took 0.40s.
[   18.538854] init: Waiting for /dev/.coldboot_done took 0.41s.
[   18.545211] init: /dev/hw_random not found
[   18.551491] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.560239] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.570692] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.583966] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[   18.593650] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[   18.606591] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.614912] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[   18.625888] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.639184] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[   18.647577] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[   18.657529] type=1400 audit(1262304013.670:3): avc:  denied  { create } for  pid=1 comm="init" name="sdcard" scontext=u:r:init:s0 tcontext=u:object_r:tmpfs:s0 tclass=lnk_file permissive=0
[   18.676549] type=1400 audit(1262304013.690:4): avc:  denied  { create } for  pid=1 comm="init" name="extsd" scontext=u:r:init:s0 tcontext=u:object_r:tmpfs:s0 tclass=lnk_file permissive=0
[   18.695584] type=1400 audit(1262304013.710:5): avc:  denied  { create } for  pid=1 comm="init" name="usbhost" scontext=u:r:init:s0 tcontext=u:object_r:tmpfs:s0 tclass=lnk_file permissive=0
[   18.714477] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.722911] init: /dev/hw_random not found
[   18.745505] type=1400 audit(1262304013.760:6): avc:  denied  { sys_module } for  pid=1 comm="init" capability=16  scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[   18.766724] init: Warning!  Service exec 0 (/sbin/busybox) needs a SELinux domain defined; please fix!
[   18.776970] init: Starting service 'exec 0 (/sbin/busybox)'...
[   18.784117] type=1400 audit(1262304013.800:7): avc:  denied  { execute_no_trans } for  pid=1375 comm="init" path="/sbin/busybox" dev="rootfs" ino=3976 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   18.806122] init: cannot execve('/sbin/busybox'): Permission denied
[   18.813273] init: Service 'exec 0 (/sbin/busybox)' (pid 1375) exited with status 127
[   37.847231] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   37.856271] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: No such file or directory
(02-04-2016, 05:15 PM)taros Wrote: Trying again and writing down the steps (in order to catch any mistake).
Your steps seems fine. I removed the kernel parameter.
Here is the image: https://drive.google.com/file/d/0B5NrIPX...ef=2&pli=1
I used this new boot.img:
$ sha256sum boot.img
4b87d6c6af1b2632180301a3d87876a86dae01dc7d7d3c8c82311db0314c1668  boot.img
Here is the new output:
[   17.767780] Freeing unused kernel memory: 524K (ffffffc0009e5000 - ffffffc000a68000)
[   17.778560] init: init started!
[   17.791933] SELinux: 2048 avtab hash slots, 4930 rules.
[   17.803192] SELinux: 2048 avtab hash slots, 4930 rules.
[   17.808952] SELinux:  1 users, 2 roles, 531 types, 0 bools, 1 sens, 1024 cats
[   17.816800] SELinux:  87 classes, 4930 rules
[   17.824896] SELinux:  Completing initialization.
[   17.829940] SELinux:  Setting up existing superblocks.
[   17.835579] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.843382] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[   17.851481] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[   17.859871] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   17.867501] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.875421] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[   17.884296] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[   17.897376] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   17.904924] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   17.912436] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[   17.922336] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[   17.930445] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[   17.939075] SELinux: initialized (dev configfs, type configfs), not configured for labeling
[   17.948208] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.956123] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   18.154688] type=1403 audit(1262304012.930:2): policy loaded auid=4294967295 ses=4294967295
[   18.164545] init: (Initializing SELinux enforcing took 0.39s.)
[   18.177158] init: init second stage started!
[   18.234672] init: waitpid failed: No child processes
[   18.240378] init: (Loading properties from /default.prop took 0.00s.)
[   18.249484] init: (Parsing /init.environ.rc took 0.00s.)
[   18.255599] init: (Parsing /init.usb.rc took 0.00s.)
[   18.261709] init: (Parsing init.common.rc took 0.00s.)
[   18.267541] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   18.274007] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   18.280118] init: (Parsing /init.sun50iw1p1.rc took 0.02s.)
[   18.286596] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   18.292962] init: /init.zygote64_32.rc: 1: ignored duplicate definition of service 'zygote'
[   18.302117] init: /init.zygote64_32.rc: 10: ignored duplicate definition of service 'zygote_secondary'
[   18.312305] init: (Parsing /init.zygote64_32.rc took 0.02s.)
[   18.318642] init: (Parsing /init.trace.rc took 0.00s.)
[   18.324317] init: could not import file '/init.cm.rc' from '/init.rc'
[   18.331375] init: (Parsing /init.rc took 0.08s.)
[   18.336673] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[   18.347129] init: Starting service 'ueventd'...
[   18.352455] init: Waiting for /dev/.coldboot_done...
[   18.354686] ueventd: ueventd started!
[   18.753818] ueventd: Coldboot took 0.40s.
[   18.759894] init: Waiting for /dev/.coldboot_done took 0.41s.
[   18.766261] init: /dev/hw_random not found
[   18.772500] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.781254] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.791814] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.805106] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[   18.814740] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[   18.827723] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.836045] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[   18.847025] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.860322] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[   18.868795] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[   18.880572] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.889015] init: /dev/hw_random not found
[   18.923466] [NAND]Failed to insmod nand!!!
[   18.931012] init: Warning!  Service exec 0 (/sbin/busybox) needs a SELinux domain defined; please fix!
[   18.941217] init: Starting service 'exec 0 (/sbin/busybox)'...
[   18.948333] type=1400 audit(1262304013.740:3): avc:  denied  { execute_no_trans } for  pid=1379 comm="init" path="/sbin/busybox" dev="rootfs" ino=3976 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   18.970359] init: cannot execve('/sbin/busybox'): Permission denied
[   18.977513] init: Service 'exec 0 (/sbin/busybox)' (pid 1379) exited with status 127
[   38.071038] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   38.080097] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: No such file or directory
[   57.746185] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=-1
[   57.755012] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/cache at /cache options: nomblk_io_submit,barrier=1 error: No such file or directory
[   77.432525] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=-1
[   77.441348] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/alog at /logger options: nomblk_io_submit,barrier=1 error: No such file or directory
[   97.109003] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=-1
[   97.117737] fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/UDISK for mount /data type ext4 )
[   97.130137] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   97.138114] init: fs_mgr_mount_all returned an error
[   97.143859] init: fs_mgr_mount_all returned unexpected error 255
[   97.150852] init: cannot find '/system/bin/app_process64', disabling 'zygote'
[   97.158713] init: cannot find '/system/bin/app_process32', disabling 'zygote_secondary'
[   97.167516] init: cannot find '/system/bin/sh', disabling 'console'
[   97.177926] Unable to find swap-space signature
[   97.182937] fs_mgr: swapon failed for /dev/block/zram0
[   97.188716] init: cannot find '/system/bin/installd', disabling 'installd'
[   97.196317] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.204054] init: SELinux: Could not set context for /cache:  Read-only file system
[   97.214308] init: SELinux: Could not set context for /logger:  Read-only file system
[   97.223042] init: (Loading properties from /system/build.prop took 0.00s.)
[   97.230633] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   97.238205] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   97.246254] init: /recovery not specified in fstab
[   97.252607] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.259439] init: cannot find '/system/bin/vold', disabling 'vold'
[   97.266726] init: Not bootcharting.
[   97.298259] init: SELinux: Could not get canonical path /data/user/0 restorecon: No such file or directory.
[   97.309005] init: cannot find '/system/bin/tzdatacheck', disabling 'exec 1 (/system/bin/tzdatacheck)'
[   97.319862] init: cannot find '/system/bin/gatekeeperd', disabling 'gatekeeperd'
[   97.328006] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[   97.336132] init: cannot find '/system/bin/sdcard', disabling 'sdcard'
[   97.343613] init: Warning!  Service bootclone needs a SELinux domain defined; please fix!
[   97.352568] init: Starting service 'bootclone'...
[   97.358464] type=1400 audit(1262304093.420:4): avc:  denied  { execute_no_trans } for  pid=1382 comm="init" path="/sbin/busybox" dev="rootfs" ino=3976 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.358491] init: Warning!  Service precopy needs a SELinux domain defined; please fix!
[   97.358502] init: Starting service 'precopy'...
[   97.359047] init: (Loading properties from /data/local.prop took 0.00s.)
[   97.359149] type=1400 audit(1262304093.420:5): avc:  denied  { execute_no_trans } for  pid=1383 comm="init" path="/sbin/busybox" dev="rootfs" ino=3976 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.359209] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.359211] init: cannot execve('/sbin/busybox'): Permission denied
[   97.359266] init: cannot find '/system/bin/logd', disabling 'logd-reinit'
[   97.359885] init: Service 'precopy' (pid 1383) exited with status 127
[   97.365000] init: Starting service 'healthd'...
[   97.365502] init: cannot find '/system/bin/lmkd', disabling 'lmkd'
[   97.365552] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[   97.365623] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[   97.365699] init: cannot find '/system/bin/sayeye', disabling 'sayeye'
[   97.367731] binder: 1384:1384 transaction failed 29189, size 0-0
[   97.368459] init: write_file: Unable to open '/proc/bluetooth/sleep/lpm': No such file or directory
[   97.370506] init: cannot find '/system/bin/sh', disabling 'console'
[   97.370671] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.370731] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': No such file or directory
[   97.370833] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': No such file or directory
[   97.370896] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such file or directory
[   97.370953] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.371011] init: Starting service 'adbd'...
[   97.571998] init: cannot execve('/sbin/busybox'): Permission denied
[   97.579201] init: Service 'bootclone' (pid 1382) exited with status 127
[   98.351849] binder: 1384:1384 transaction failed 29189, size 0-0
[   99.342509] binder: 1384:1384 transaction failed 29189, size 0-0
[  100.333175] binder: 1384:1384 transaction failed 29189, size 0-0
[  101.323804] binder: 1384:1384 transaction failed 29189, size 0-0
[  102.314565] binder: 1384:1384 transaction failed 29189, size 0-0
[  103.305209] binder: 1384:1384 transaction failed 29189, size 0-0
[  104.295837] binder: 1384:1384 transaction failed 29189, size 0-0
[  105.287015] binder: 1384:1384 transaction failed 29189, size 0-0
[  106.277660] binder: 1384:1384 transaction failed 29189, size 0-0
[  107.268287] binder: 1384:1384 transaction failed 29189, size 0-0
[  108.259079] binder: 1384:1384 transaction failed 29189, size 0-0
[  109.249722] binder: 1384:1384 transaction failed 29189, size 0-0
[  110.240350] binder: 1384:1384 transaction failed 29189, size 0-0
[  111.231084] binder: 1384:1384 transaction failed 29189, size 0-0
[  112.221727] binder: 1384:1384 transaction failed 29189, size 0-0
[  113.212355] binder: 1384:1384 transaction failed 29189, size 0-0
[  114.203069] binder: 1384:1384 transaction failed 29189, size 0-0
[  115.193712] binder: 1384:1384 transaction failed 29189, size 0-0
[  116.184340] binder: 1384:1384 transaction failed 29189, size 0-0
[  117.175046] binder: 1384:1384 transaction failed 29189, size 0-0
[  118.165690] binder: 1384:1384 transaction failed 29189, size 0-0
[  119.156317] binder: 1384:1384 transaction failed 29189, size 0-0
[  120.147009] binder: 1384:1384 transaction failed 29189, size 0-0
[  121.137650] binder: 1384:1384 transaction failed 29189, size 0-0
[  122.128277] binder: 1384:1384 transaction failed 29189, size 0-0
[  123.118905] binder: 1384:1384 transaction failed 29189, size 0-0
[  124.109599] binder: 1384:1384 transaction failed 29189, size 0-0
[  125.100243] binder: 1384:1384 transaction failed 29189, size 0-0
[  126.090869] binder: 1384:1384 transaction failed 29189, size 0-0
Among the issues:
1. /sbin/busybox does not have a SELinux domain, and does not run.
2. the system partition (and other partitions) cannot be mounted
If busybox could work, then it would be poke inside and find why the partitions are not being mounted.
(02-05-2016, 06:47 AM)taros Wrote: If busybox could work, then it would be poke inside and find why the partitions are not being mounted.
I've fixed a mistake in my device tree which caused some missing sepolicies and ramdisk files.
System partition has changed a bit but I'll upload it when we will be able to at least mount it Smile
Here is the new image:
I tried it out.
96ca2edf6ee812ed214eb5d1b592b456acb481d47c47d2858bcc11d65fd5a801  boot.img
The output is
[   17.757254] Freeing unused kernel memory: 524K (ffffffc0009e5000 - ffffffc000a68000)
[   17.768049] init: init started!
[   17.781578] SELinux: 2048 avtab hash slots, 5277 rules.
[   17.793212] SELinux: 2048 avtab hash slots, 5277 rules.
[   17.798966] SELinux:  1 users, 2 roles, 561 types, 0 bools, 1 sens, 1024 cats
[   17.806816] SELinux:  87 classes, 5277 rules
[   17.814952] SELinux:  Completing initialization.
[   17.819996] SELinux:  Setting up existing superblocks.
[   17.825646] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.833505] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[   17.841553] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[   17.849938] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   17.857568] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.865482] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[   17.874358] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[   17.887411] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   17.894958] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   17.902483] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[   17.912381] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[   17.920480] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[   17.929112] SELinux: initialized (dev configfs, type configfs), not configured for labeling
[   17.938246] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.946159] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   18.144116] type=1403 audit(1262304012.930:2): policy loaded auid=4294967295 ses=4294967295
[   18.153986] init: (Initializing SELinux enforcing took 0.39s.)
[   18.167120] init: init second stage started!
[   18.228481] init: waitpid failed: No child processes
[   18.234131] init: (Loading properties from /default.prop took 0.00s.)
[   18.243235] init: (Parsing /init.environ.rc took 0.00s.)
[   18.249454] init: (Parsing /init.usb.rc took 0.00s.)
[   18.255469] init: (Parsing init.common.rc took 0.00s.)
[   18.261302] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   18.267784] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   18.273879] init: (Parsing /init.sun50iw1p1.rc took 0.02s.)
[   18.280365] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   18.286729] init: /init.zygote64_32.rc: 1: ignored duplicate definition of service 'zygote'
[   18.295885] init: /init.zygote64_32.rc: 10: ignored duplicate definition of service 'zygote_secondary'
[   18.306091] init: (Parsing /init.zygote64_32.rc took 0.02s.)
[   18.312401] init: (Parsing /init.trace.rc took 0.00s.)
[   18.318469] init: (Parsing /init.superuser.rc took 0.00s.)
[   18.324468] init: (Parsing /init.cm.rc took 0.01s.)
[   18.329846] init: (Parsing /init.rc took 0.09s.)
[   18.335125] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[   18.345589] init: Starting service 'ueventd'...
[   18.350931] init: Waiting for /dev/.coldboot_done...
[   18.353178] ueventd: ueventd started!
[   18.755318] ueventd: Coldboot took 0.40s.
[   18.758390] init: Waiting for /dev/.coldboot_done took 0.41s.
[   18.758477] init: /dev/hw_random not found
[   18.758601] keychord: using input dev sunxi_ir_recv for fevent
[   18.758608] keychord: using input dev MCE IR Keyboard/Mouse (sunxi-rc-recv) for fevent
[   18.758613] keychord: using input dev axp81x-supplyer for fevent
[   18.758619] keychord: using input dev audiocodec sunxi Audio Jack for fevent
[   18.801427] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.810259] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.820798] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.834062] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[   18.843687] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[   18.856538] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.864829] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[   18.875772] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.889110] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[   18.897434] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[   18.909384] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.918951] init: /dev/hw_random not found
[   18.953473] [NAND]Failed to insmod nand!!!
[   18.961225] init: Warning!  Service exec 0 (/sbin/busybox) needs a SELinux domain defined; please fix!
[   18.971428] init: Starting service 'exec 0 (/sbin/busybox)'...
[   18.978523] type=1400 audit(1262304013.780:3): avc:  denied  { execute_no_trans } for  pid=1379 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   19.000539] init: cannot execve('/sbin/busybox'): Permission denied
[   19.007738] init: Service 'exec 0 (/sbin/busybox)' (pid 1379) exited with status 127
[   38.061672] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   38.070714] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: No such file or directory
[   57.736797] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=-1
[   57.745625] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/cache at /cache options: nomblk_io_submit,barrier=1 error: No such file or directory
[   77.423242] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=-1
[   77.432064] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/alog at /logger options: nomblk_io_submit,barrier=1 error: No such file or directory
[   97.099864] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=-1
[   97.108596] fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/UDISK for mount /data type ext4 )
[   97.120996] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   97.128998] init: fs_mgr_mount_all returned an error
[   97.134787] init: fs_mgr_mount_all returned unexpected error 255
[   97.141453] init: cannot find '/system/bin/app_process64', disabling 'zygote'
[   97.149632] init: cannot find '/system/bin/app_process32', disabling 'zygote_secondary'
[   97.158439] init: cannot find '/system/bin/sh', disabling 'console'
[   97.168848] Unable to find swap-space signature
[   97.173883] fs_mgr: swapon failed for /dev/block/zram0
[   97.179634] init: cannot find '/system/bin/installd', disabling 'installd'
[   97.187239] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.194981] init: SELinux: Could not set context for /cache:  Read-only file system
[   97.205308] init: SELinux: Could not set context for /logger:  Read-only file system
[   97.214062] init: (Loading properties from /system/build.prop took 0.00s.)
[   97.221635] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   97.229214] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   97.237228] init: /recovery not specified in fstab
[   97.243686] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.250489] init: cannot find '/system/bin/vold', disabling 'vold'
[   97.257771] init: Not bootcharting.
[   97.290195] init: SELinux: Could not get canonical path /data/user/0 restorecon: No such file or directory.
[   97.300973] init: cannot find '/system/bin/tzdatacheck', disabling 'exec 1 (/system/bin/tzdatacheck)'
[   97.311856] init: cannot find '/system/bin/gatekeeperd', disabling 'gatekeeperd'
[   97.319990] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[   97.327846] init: cannot find '/system/bin/sdcard', disabling 'sdcard'
[   97.335302] init: Warning!  Service bootclone needs a SELinux domain defined; please fix!
[   97.344506] init: Starting service 'bootclone'...
[   97.350433] type=1400 audit(1262304093.420:4): avc:  denied  { execute_no_trans } for  pid=1382 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.350484] init: Warning!  Service precopy needs a SELinux domain defined; please fix!
[   97.350495] init: Starting service 'precopy'...
[   97.351150] type=1400 audit(1262304093.430:5): avc:  denied  { execute_no_trans } for  pid=1383 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.351215] init: cannot execve('/sbin/busybox'): Permission denied
[   97.351537] init: Service 'precopy' (pid 1383) exited with status 127
[   97.352302] init: cannot find '/system/bin/sysinit', disabling 'sysinit'
[   97.352409] init: (Loading properties from /data/local.prop took 0.00s.)
[   97.352549] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.352602] init: cannot find '/system/bin/logd', disabling 'logd-reinit'
[   97.357962] init: Starting service 'healthd'...
[   97.358491] init: cannot find '/system/bin/lmkd', disabling 'lmkd'
[   97.358541] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[   97.358608] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[   97.358688] init: cannot find '/system/bin/sayeye', disabling 'sayeye'
[   97.361157] binder: 1384:1384 transaction failed 29189, size 0-0
[   97.361521] init: write_file: Unable to open '/proc/bluetooth/sleep/lpm': No such file or directory
[   97.369249] init: cannot find '/system/bin/sh', disabling 'console'
[   97.369414] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.369475] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': No such file or directory
[   97.369537] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': No such file or directory
[   97.369598] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such file or directory
[   97.369654] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.369702] init: Starting service 'adbd'...
[   97.571114] init: cannot execve('/sbin/busybox'): Permission denied
[   97.578329] init: Service 'bootclone' (pid 1382) exited with status 127
[   98.345274] binder: 1384:1384 transaction failed 29189, size 0-0
[   99.335916] binder: 1384:1384 transaction failed 29189, size 0-0
[  100.326586] binder: 1384:1384 transaction failed 29189, size 0-0
[  101.317472] binder: 1384:1384 transaction failed 29189, size 0-0
[  102.308100] binder: 1384:1384 transaction failed 29189, size 0-0
[  103.298759] binder: 1384:1384 transaction failed 29189, size 0-0
[  104.289874] binder: 1384:1384 transaction failed 29189, size 0-0
[  105.280502] binder: 1384:1384 transaction failed 29189, size 0-0
[  106.271163] binder: 1384:1384 transaction failed 29189, size 0-0
[  107.261919] binder: 1384:1384 transaction failed 29189, size 0-0
[  108.252546] binder: 1384:1384 transaction failed 29189, size 0-0
[  109.243204] binder: 1384:1384 transaction failed 29189, size 0-0
[  110.233952] binder: 1384:1384 transaction failed 29189, size 0-0
[  111.224580] binder: 1384:1384 transaction failed 29189, size 0-0
[  112.215237] binder: 1384:1384 transaction failed 29189, size 0-0
[  113.205949] binder: 1384:1384 transaction failed 29189, size 0-0
[  114.196604] binder: 1384:1384 transaction failed 29189, size 0-0
[  115.187232] binder: 1384:1384 transaction failed 29189, size 0-0
[  116.177926] binder: 1384:1384 transaction failed 29189, size 0-0
[  117.168570] binder: 1384:1384 transaction failed 29189, size 0-0
[  118.159197] binder: 1384:1384 transaction failed 29189, size 0-0
[  119.149895] binder: 1384:1384 transaction failed 29189, size 0-0
If you can write up (or point me to a howto) on how to recreate the boot.img, I can try as well.
Thanks for going through this!
(02-07-2016, 07:55 AM)taros Wrote: If you can write up (or point me to a howto) on how to recreate the boot.img, I can try as well.
Here is the new boot image: https://drive.google.com/file/d/0B5NrIPX...sp=sharing
Also I've investigated much more about partitions. It seems busybox runs a script named init_partitions.sh which does something about partitions.
I hope busybox can run this time.
I'm creating these boot images with ROM so I have downloaded CM sources and created a device tree
which is based on these sources http://www.cnx-software.com/2015/12/10/a...urce-code/
I will put the edited device tree sources on github once ROM starts to boot.
I tried out the new boot.img,
fbfe7b55b7e7f57d75ef38482032fef971c84ceb171d548efbd97893927c3f41  boot.img
Here are the logs,
[   17.759624] Freeing unused kernel memory: 524K (ffffffc0009e5000 - ffffffc000a68000)
[   17.770423] init: init started!
[   17.783885] SELinux: 2048 avtab hash slots, 5277 rules.
[   17.795535] SELinux: 2048 avtab hash slots, 5277 rules.
[   17.801277] SELinux:  1 users, 2 roles, 561 types, 0 bools, 1 sens, 1024 cats
[   17.809085] SELinux:  87 classes, 5277 rules
[   17.817166] SELinux:  Completing initialization.
[   17.822211] SELinux:  Setting up existing superblocks.
[   17.827877] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.835692] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[   17.843740] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[   17.852118] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   17.859752] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.867666] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[   17.876536] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[   17.889549] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   17.897101] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   17.904627] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[   17.914524] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[   17.922625] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[   17.931257] SELinux: initialized (dev configfs, type configfs), not configured for labeling
[   17.940391] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.948303] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   18.145452] type=1403 audit(1262304012.920:2): policy loaded auid=4294967295 ses=4294967295
[   18.155317] init: (Initializing SELinux enforcing took 0.39s.)
[   18.168442] init: init second stage started!
[   18.229869] init: waitpid failed: No child processes
[   18.235519] init: (Loading properties from /default.prop took 0.00s.)
[   18.244602] init: (Parsing /init.environ.rc took 0.00s.)
[   18.250814] init: (Parsing /init.usb.rc took 0.00s.)
[   18.256826] init: (Parsing init.common.rc took 0.00s.)
[   18.262664] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   18.269145] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   18.275240] init: (Parsing /init.sun50iw1p1.rc took 0.02s.)
[   18.281729] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   18.288110] init: /init.zygote64_32.rc: 1: ignored duplicate definition of service 'zygote'
[   18.297271] init: /init.zygote64_32.rc: 10: ignored duplicate definition of service 'zygote_secondary'
[   18.307463] init: (Parsing /init.zygote64_32.rc took 0.02s.)
[   18.313776] init: (Parsing /init.trace.rc took 0.00s.)
[   18.319833] init: (Parsing /init.superuser.rc took 0.00s.)
[   18.325832] init: (Parsing /init.cm.rc took 0.01s.)
[   18.331182] init: (Parsing /init.rc took 0.09s.)
[   18.336456] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[   18.346946] init: Starting service 'ueventd'...
[   18.352297] init: Waiting for /dev/.coldboot_done...
[   18.354516] ueventd: ueventd started!
[   18.755285] ueventd: Coldboot took 0.40s.
[   18.759962] init: Waiting for /dev/.coldboot_done took 0.41s.
[   18.766320] init: /dev/hw_random not found
[   18.770963] keychord: using input dev sunxi_ir_recv for fevent
[   18.777334] keychord: using input dev MCE IR Keyboard/Mouse (sunxi-rc-recv) for fevent
[   18.786504] keychord: using input dev axp81x-supplyer for fevent
[   18.793077] keychord: using input dev audiocodec sunxi Audio Jack for fevent
[   18.802544] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.811801] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.822314] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.835626] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[   18.845318] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[   18.858209] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.866487] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[   18.877498] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.890864] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[   18.899267] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[   18.911030] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.920647] init: /dev/hw_random not found
[   18.955285] [NAND]Failed to insmod nand!!!
[   18.963011] init: Warning!  Service exec 0 (/sbin/busybox) needs a SELinux domain defined; please fix!
[   18.973214] init: Starting service 'exec 0 (/sbin/busybox)'...
[   18.980352] type=1400 audit(1262304013.780:3): avc:  denied  { execute_no_trans } for  pid=1380 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   19.002355] init: cannot execve('/sbin/busybox'): Permission denied
[   19.009517] init: Service 'exec 0 (/sbin/busybox)' (pid 1380) exited with status 127
[   38.073612] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   38.082640] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: No such file or directory
[   57.748671] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=-1
[   57.757512] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/cache at /cache options: nomblk_io_submit,barrier=1 error: No such file or directory
[   77.435145] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=-1
[   77.443968] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/alog at /logger options: nomblk_io_submit,barrier=1 error: No such file or directory
[   97.111583] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=-1
[   97.120316] fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/UDISK for mount /data type ext4 )
[   97.132714] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   97.140713] init: fs_mgr_mount_all returned an error
[   97.146496] init: fs_mgr_mount_all returned unexpected error 255
[   97.153160] init: cannot find '/system/bin/app_process64', disabling 'zygote'
[   97.161333] init: cannot find '/system/bin/app_process32', disabling 'zygote_secondary'
[   97.170136] init: cannot find '/system/bin/sh', disabling 'console'
[   97.180484] Unable to find swap-space signature
[   97.185517] fs_mgr: swapon failed for /dev/block/zram0
[   97.191271] init: cannot find '/system/bin/installd', disabling 'installd'
[   97.198876] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.206623] init: SELinux: Could not set context for /cache:  Read-only file system
[   97.216936] init: SELinux: Could not set context for /logger:  Read-only file system
[   97.225695] init: (Loading properties from /system/build.prop took 0.00s.)
[   97.233267] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   97.240847] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   97.248860] init: /recovery not specified in fstab
[   97.255328] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.262131] init: cannot find '/system/bin/vold', disabling 'vold'
[   97.269439] init: Not bootcharting.
[   97.301763] init: SELinux: Could not get canonical path /data/user/0 restorecon: No such file or directory.
[   97.312540] init: cannot find '/system/bin/tzdatacheck', disabling 'exec 1 (/system/bin/tzdatacheck)'
[   97.323414] init: cannot find '/system/bin/gatekeeperd', disabling 'gatekeeperd'
[   97.331547] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[   97.339407] init: cannot find '/system/bin/sdcard', disabling 'sdcard'
[   97.346864] init: Warning!  Service bootclone needs a SELinux domain defined; please fix!
[   97.356069] init: Starting service 'bootclone'...
[   97.362003] type=1400 audit(1262304093.430:4): avc:  denied  { execute_no_trans } for  pid=1383 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.362025] init: Warning!  Service precopy needs a SELinux domain defined; please fix!
[   97.362036] init: Starting service 'precopy'...
[   97.362680] type=1400 audit(1262304093.430:5): avc:  denied  { execute_no_trans } for  pid=1384 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.362739] init: cannot execve('/sbin/busybox'): Permission denied
[   97.363072] init: Service 'precopy' (pid 1384) exited with status 127
[   97.363834] init: cannot find '/system/bin/sysinit', disabling 'sysinit'
[   97.363941] init: (Loading properties from /data/local.prop took 0.00s.)
[   97.364087] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.364143] init: cannot find '/system/bin/logd', disabling 'logd-reinit'
[   97.369477] init: Starting service 'healthd'...
[   97.369995] init: cannot find '/system/bin/lmkd', disabling 'lmkd'
[   97.370046] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[   97.370115] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[   97.370197] init: cannot find '/system/bin/sayeye', disabling 'sayeye'
[   97.372584] binder: 1385:1385 transaction failed 29189, size 0-0
[   97.373047] init: write_file: Unable to open '/proc/bluetooth/sleep/lpm': No such file or directory
[   97.380799] init: cannot find '/system/bin/sh', disabling 'console'
[   97.380962] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.381019] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': No such file or directory
[   97.381080] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': No such file or directory
[   97.381137] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such file or directory
[   97.381194] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.381287] init: Starting service 'adbd'...
[   97.582685] init: cannot execve('/sbin/busybox'): Permission denied
[   97.589900] init: Service 'bootclone' (pid 1383) exited with status 127
[   98.356700] binder: 1385:1385 transaction failed 29189, size 0-0
[   99.347342] binder: 1385:1385 transaction failed 29189, size 0-0
[  100.338012] binder: 1385:1385 transaction failed 29189, size 0-0
The logs between this and the previous boot.img show no difference, https://www.diffchecker.com/whcbcrjc
(02-07-2016, 04:30 PM)taros Wrote: The logs between this and the previous boot.img show no difference, https://www.diffchecker.com/whcbcrjc
I hope this time logs will change  Smile
#19
Fresh out of the Pine64:
[   17.760962] Freeing unused kernel memory: 524K (ffffffc0009e5000 - ffffffc000a68000)
[   17.771723] init: init started!
[   17.785265] SELinux: 2048 avtab hash slots, 5295 rules.
[   17.796926] SELinux: 2048 avtab hash slots, 5295 rules.
[   17.802682] SELinux:  1 users, 2 roles, 562 types, 0 bools, 1 sens, 1024 cats
[   17.810534] SELinux:  87 classes, 5295 rules
[   17.818675] SELinux:  Completing initialization.
[   17.823720] SELinux:  Setting up existing superblocks.
[   17.829358] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.837216] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[   17.845265] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[   17.853653] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   17.861290] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.869203] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[   17.878075] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[   17.891013] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   17.898569] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   17.906095] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[   17.915994] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[   17.924098] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[   17.932729] SELinux: initialized (dev configfs, type configfs), not configured for labeling
[   17.941863] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.949778] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   18.147795] type=1403 audit(1262304012.930:2): policy loaded auid=4294967295 ses=4294967295
[   18.157671] init: (Initializing SELinux enforcing took 0.39s.)
[   18.170791] init: init second stage started!
[   18.232236] init: waitpid failed: No child processes
[   18.237887] init: (Loading properties from /default.prop took 0.00s.)
[   18.246987] init: (Parsing /init.environ.rc took 0.00s.)
[   18.253205] init: (Parsing /init.usb.rc took 0.00s.)
[   18.259222] init: (Parsing init.common.rc took 0.00s.)
[   18.265054] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   18.271537] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   18.277632] init: (Parsing /init.sun50iw1p1.rc took 0.02s.)
[   18.284117] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   18.290482] init: /init.zygote64_32.rc: 1: ignored duplicate definition of service 'zygote'
[   18.299638] init: /init.zygote64_32.rc: 10: ignored duplicate definition of service 'zygote_secondary'
[   18.309845] init: (Parsing /init.zygote64_32.rc took 0.02s.)
[   18.316158] init: (Parsing /init.trace.rc took 0.00s.)
[   18.322222] init: (Parsing /init.superuser.rc took 0.00s.)
[   18.328221] init: (Parsing /init.cm.rc took 0.01s.)
[   18.333600] init: (Parsing /init.rc took 0.09s.)
[   18.338893] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[   18.349352] init: Starting service 'ueventd'...
[   18.354689] init: Waiting for /dev/.coldboot_done...
[   18.356955] ueventd: ueventd started!
[   18.759385] ueventd: Coldboot took 0.40s.
[   18.762196] init: Waiting for /dev/.coldboot_done took 0.41s.
[   18.762292] init: /dev/hw_random not found
[   18.762418] keychord: using input dev sunxi_ir_recv for fevent
[   18.762425] keychord: using input dev MCE IR Keyboard/Mouse (sunxi-rc-recv) for fevent
[   18.762430] keychord: using input dev axp81x-supplyer for fevent
[   18.762436] keychord: using input dev audiocodec sunxi Audio Jack for fevent
[   18.805386] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.814151] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.824793] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.838135] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[   18.847764] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[   18.860790] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.869075] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[   18.880030] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.893342] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[   18.901743] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[   18.913543] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.923117] init: /dev/hw_random not found
[   18.957740] [NAND]Failed to insmod nand!!!
[   18.962965] init: Starting service 'busybox'...
[   18.970263] type=1400 audit(1262304013.770:3): avc:  denied  { execute_no_trans } for  pid=1380 comm="busybox" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:busybox:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[   18.993318] type=1400 audit(1262304013.790:4): avc:  denied  { write } for  pid=1380 comm="busybox" name="block" dev="tmpfs" ino=1861 scontext=u:r:busybox:s0 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[   19.014656] type=1400 audit(1262304013.810:5): avc:  denied  { add_name } for  pid=1380 comm="busybox" name="by-name" scontext=u:r:busybox:s0 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[   19.034332] type=1400 audit(1262304013.830:6): avc:  denied  { create } for  pid=1380 comm="busybox" name="by-name" scontext=u:r:busybox:s0 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[   19.053876] type=1400 audit(1262304013.850:7): avc:  denied  { setattr } for  pid=1380 comm="busybox" name="by-name" dev="tmpfs" ino=5491 scontext=u:r:busybox:s0 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[   19.078172] type=1400 audit(1262304013.880:8): avc:  denied  { create } for  pid=1382 comm="busybox" name="bootloader" scontext=u:r:busybox:s0 tcontext=u:object_r:block_device:s0 tclass=lnk_file permissive=1
[   19.103614] type=1400 audit(1262304013.900:9): avc:  denied  { setattr } for  pid=1387 comm="busybox" name="mmcblk0p8" dev="tmpfs" ino=1886 scontext=u:r:busybox:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[   23.890790] init: Service 'busybox' (pid 1379) exited with status 0
[   23.900674] EXT4-fs (mmcblk0p7): VFS: Can't find ext4 filesystem
[   23.907483] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   23.918082] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: Invalid argument
[   23.942931] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[   23.968561] EXT4-fs (mmcblk0p10): recovery complete
[   23.973896] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[   23.985522] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
[   23.992966] fs_mgr: check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=0: Success
[   24.003827] fs_mgr: check_fs(): unmount(/cache) succeeded
[   24.009806] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/cache (executable not in system image)
[   24.022112] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[   24.045090] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,barrier=1
[   24.055950] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
[   24.063337] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=0
[   24.081650] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[   24.482029] EXT4-fs (mmcblk0p13): recovery complete
[   24.487365] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[   24.499232] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
[   24.506654] fs_mgr: check_fs(): mount(/dev/block/by-name/alog,/logger,ext4)=0: Success
[   24.579348] fs_mgr: check_fs(): unmount(/logger) succeeded
[   24.585407] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/alog (executable not in system image)
[   24.597508] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[   24.622120] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,barrier=1
[   24.632988] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
[   24.640381] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=0
[   24.659961] EXT4-fs (mmcblk0p1): Ignoring removed nomblk_io_submit option
[   25.059544] EXT4-fs (mmcblk0p1): recovery complete
[   25.064802] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[   25.076322] SELinux: initialized (dev mmcblk0p1, type ext4), uses xattr
[   25.083656] fs_mgr: check_fs(): mount(/dev/block/by-name/UDISK,/data,ext4)=0: Success
[   25.128031] fs_mgr: check_fs(): unmount(/data) succeeded
[   25.133911] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/UDISK (executable not in system image)
[   25.146139] EXT4-fs (mmcblk0p1): Ignoring removed nomblk_io_submit option
[   25.170979] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,barrier=1,noauto_da_alloc
[   25.183276] SELinux: initialized (dev mmcblk0p1, type ext4), uses xattr
[   25.190588] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=0
[   25.199236] init: fs_mgr_mount_all returned an error
[   25.204995] init: fs_mgr_mount_all returned unexpected error 255
[   25.211692] init: cannot find '/system/bin/app_process64', disabling 'zygote'
[   25.220472] init: cannot find '/system/bin/app_process32', disabling 'zygote_secondary'
[   25.229276] init: cannot find '/system/bin/sh', disabling 'console'
[   25.239682] Unable to find swap-space signature
[   25.244689] fs_mgr: swapon failed for /dev/block/zram0
[   25.250473] init: cannot find '/system/bin/installd', disabling 'installd'
[   25.258079] init: cannot find '/system/bin/logd', disabling 'logd'
[   25.291309] init: (Loading properties from /system/build.prop took 0.00s.)
[   25.298963] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   25.306538] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   25.314553] init: /recovery not specified in fstab
[   25.323351] init: cannot find '/system/bin/logd', disabling 'logd'
[   25.330193] init: cannot find '/system/bin/vold', disabling 'vold'
[   25.338914] init: Not bootcharting.
[   25.623218] init: cannot find '/system/bin/tzdatacheck', disabling 'exec 0 (/system/bin/tzdatacheck)'
[   25.634168] init: cannot find '/system/bin/gatekeeperd', disabling 'gatekeeperd'
[   25.642359] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[   25.650224] init: cannot find '/system/bin/sdcard', disabling 'sdcard'
[   25.659641] init: Warning!  Service bootclone needs a SELinux domain defined; please fix!
[   25.668594] init: Starting service 'bootclone'...
[   25.674531] type=1400 audit(1262304020.580:10): avc:  denied  { execute_no_trans } for  pid=1410 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   25.674584] init: Warning!  Service precopy needs a SELinux domain defined; please fix!
[   25.674595] init: Starting service 'precopy'...
[   25.675247] type=1400 audit(1262304020.580:11): avc:  denied  { execute_no_trans } for  pid=1411 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   25.675302] init: cannot execve('/sbin/busybox'): Permission denied
[   25.677030] init: Service 'precopy' (pid 1411) exited with status 127
[   25.678143] init: cannot find '/system/bin/sysinit', disabling 'sysinit'
[   25.678253] init: (Loading properties from /data/local.prop took 0.00s.)
[   25.760897] init: cannot execve('/sbin/busybox'): Permission denied
[   26.165407] init: Service 'bootclone' (pid 1410) exited with status 127
[   26.172830] init: cannot find '/system/bin/logd', disabling 'logd'
[   26.179642] init: cannot find '/system/bin/logd', disabling 'logd-reinit'
[   26.192667] init: Starting service 'healthd'...
[   26.198177] init: cannot find '/system/bin/lmkd', disabling 'lmkd'
[   26.200415] binder: 1412:1412 transaction failed 29189, size 0-0
[   26.211653] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[   26.220353] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[   26.229106] init: cannot find '/system/bin/sayeye', disabling 'sayeye'
[   26.238951] init: write_file: Unable to open '/proc/bluetooth/sleep/lpm': No such file or directory
[   26.256650] init: cannot find '/system/bin/sh', disabling 'console'
[   26.263677] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   26.274890] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': No such file or directory
[   26.286296] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': No such file or directory
[   26.297762] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such file or directory
[   26.309293] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   26.320466] init: Starting service 'adbd'...
[   27.184538] binder: 1412:1412 transaction failed 29189, size 0-0
[   28.175215] binder: 1412:1412 transaction failed 29189, size 0-0
[   29.165863] binder: 1412:1412 transaction failed 29189, size 0-0
The problem is now with system.img.
#20
(02-08-2016, 01:56 PM)taros Wrote: The problem is now with system.img.
I cannot try at the moment but this may work:
Can you mount system partiton on SD Card, when you inserted SD Card on your computer?
If yes and if its file system is ext4, can you try downloading this raw image https://drive.google.com/file/d/0B5NrIPX...sp=sharing
extract it, mount it and copy files on it to SD Card's system partition?
We are trying this to find a proper way to install system image.
  Cyanogenmod 13 GoZone 2 5,231 03-30-2016, 06:06 AM
Last Post: g_t_j
Heart CyanogenMod Danton 12 21,509 01-30-2016, 11:35 AM
