Touch screen support
(08-31-2016, 07:29 AM)shariq_2001 Wrote:
(08-30-2016, 07:38 PM)DonFL Wrote: https://www.amazon.com/Tontec%C2%AE-Rasp...WHHCSMWP7K
I originally picked this one up for the pi, have verified it works with the Pine. Probably not the best option in a space limited situation, but as a basic lcd screen, its not too bad.
Hi DonFL
Was touch available on that screen? Graphics and usability good with the pine for that LCD?
How hard was it to get going in terms of drivers and setup?
There is a touch add-on available. I messed with it for just a little bit on the Pi, it worked, but never pursued it. Got some help from a friend on the touch-screen setup, would not consider it "easy". I honestly can't really remember why I picked it (screen and touch kit) up in the first place, its been sitting on the shelf for over a year.
However, for just the screen alone, its plug and play. Power the interface board, make the hdmi connection, and you're good to go.
Graphics are clear, but its a small screen; that said, all I did was plug it in and power it up and make sure it was functional with the Pine, did not try to tweak the graphics/video settings in any way.
So just as an update, I currently have the pine64 lcd working with touch under armbian.
Everything is out there and supported, it just needs to all come together.
I'm still fiddling with still having hdmi enabled and to either have the lcd automatically detected, or a simple switch to enable it before I have anything that could be included in a build.
I will try to update with the actual steps I used if anyone is interested.
vintagewaffle Wrote:So just as an update, I currently have the pine64 lcd working with touch under armbian.
i'm really interest ton have an armbian working with the touch panel please post the steps Big Grin
or the documentation D:
thanks!
(10-26-2016, 09:55 AM)vintagewaffle Wrote: So just as an update, I currently have the pine64 lcd working with touch under armbian.
I am interested in to ... thanks for any info.
pfeerick is putting together a comprehensive thread concerning using the LCD on Linux here. Once completed, I will lock this thread and redirect queries to prevent multiple instances of same discussion.
  Is there a screen for the Rockchip RK3399 that works with FreeBSD out of the box ? ziomario 0 346 11-10-2024, 02:06 AM
Last Post: ziomario
  7 inch LCD touch panel is upside down? joshpl 2 3,009 12-07-2023, 06:18 AM
Last Post: stormwyrm
Information LCD Support on Linux pfeerick 8 22,247 02-08-2021, 03:30 PM
Last Post: HBeserra
  What other devices can the LCD screen work on? kodachrome 1 3,799 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 43,306 07-21-2017, 07:41 AM
Last Post: apple4ever
  I2C Touch Panel mbt28 0 2,549 06-12-2017, 11:32 AM
Last Post: mbt28
  Linux Support UnixOutlaw 69 111,429 03-18-2017, 07:25 PM
  LCD screen brightness/contrast Learnincurve 10 16,957 02-17-2017, 12:45 PM
Last Post: psychedup
  LCD touch panel emits low power Naccies 4 7,796 01-09-2017, 07:45 PM
  LCD Touch Screen Problem. Gavin 8 12,064 11-27-2016, 10:26 PM
Last Post: michaelquezon
