my pinecil v2 is not working
If I connect to a power supply, the display only shows calibrating, and not work. If I push the + switch under connecting the power,
it shows PD debug State 3 No Vbus. After push the - switch, only shows calibrating...
Under firmware update there are handshake errors. So I cannot step through the "calibrating" word.
The display orientation is changes, as I turn the pinecil handle to other direction....
How do I reset the unit to a working state?
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,500 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 621 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,034 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,255 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,410 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,182 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,394 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,485 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil constantly cutting out WroughtIron 1 3,292 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 2,309 01-07-2025, 03:59 PM
Last Post: MizterPink
