Pinecil v2 tip screw temperature
I just recently got a Pinecil v2 and I want to make sure that my setup doesn't have issues. The two screws which hold the tip get hot enough to burn me if I brush them while rotating the pinecil during soldering. Do your screws get hot?
Cable: anker 100W silicone usb-c cable https://www.amazon.ca/gp/aw/d/B093GGNRZM
Charging block: Apple 140W laptop charger https://www.apple.com/ca/shop/product/MW2M3AM/A/140w-usb-c-power-adapter
The device says it's getting a consistent 20V and has never posted a warning.
Firmware: v2.23-rc4
Tip: initially noticed with a ST-KU tip I got off Amazon but the original tip it shipped with also has this issue
Temps: 350-380C used while I was testing using lead free solder
Is this just something I need to be aware of and avoid touching? If so that's fine. If the entire tip is supposed to get hot it would make sense that the screws touching it also get hot.
Some searching suggests that it could be an issue with either my setup or some of the circuitry in the device and I don’t want to damage it.
  pinecil v2 dosent negotiate power moses 0 162 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 392 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 802 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,749 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 797 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,200 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,477 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,583 09-23-2025, 09:25 PM
Last Post: Escape75
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,678 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,661 05-15-2025, 01:35 AM
Last Post: autumnharris
