Pinecil V2 doesn’t power on under any circumstances
Hello everone!
I bought a pinecil v2 a few months ago, but I have only needed to use it once since I own it.
Yesterday I wanted to use it again, but I had to found out it don’t power on.
I tried with both barrel jack, and USB-C via 5-12-20V, also from two different cables.
While I hoped its firmware can be updated at least, from my PC, it doesn’t even recognised my device.
When I opened it up, everything looked normal, the joints were fine, nothing blown up.
Personally I’m a plain user not an engineer, though my assumption is that it is completely dead.
I would like to ask, what can I do in this case? Is there anything my attention passed on?
If it’s dead, I have any chance to repair?
Sorry to not really add anything other than I have similar issues. Bought in February. Never used the iron functions. Updated the firmware to adjust the settings. Plugged it back into the PC a couple of times since, no problems, usual display. Plugging it in now gives me nothing, even when I hold the minus to get to the firmware flash screen. Totally dead. I was told by support to post info here so I thought Id jump on here.
  my pinecil v2 is not working jagrav 0 626 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil v2: Use car battery for power? FZB 0 633 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,046 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,271 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,427 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,196 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,418 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,499 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil constantly cutting out WroughtIron 1 3,310 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 2,321 01-07-2025, 03:59 PM
Last Post: MizterPink
