Battery connector dead
Just to see if it happened to someone else: I just broke one of the 4 small golden battery connectors ☹
My battery was a Samsung one, it was a tad too big so it was a bit hard to set and remove, maybe it helped weaken the connectors...
I'm not sure there's an easy fix, that's why I'm asking if it happend to someone else.
If it's dead I'll recycle it as a small home server maybe to try Home Assistant or something Smile
I tried fixing the broken pin with a drop of solder then slowly shaping it with sandpaper...
I clearly lack years of soldering to achieve this cleanly. I also miss good eyes: it's too small for my eyes...
It was hard not to create a short-circuit, looks like the board right under the + pin is connected to 0V so if the solder drop is a tad too long it easily touch the board creating a short circuit. Added a patch of tape between +5V and the board to ensure they don't touch even after pressing the battery hard against it.
It works!
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 626 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 1,611 02-17-2024, 04:15 PM
Last Post: vortex
  digitizer dead Uturn 1 2,047 08-24-2023, 08:14 PM
Last Post: nroth
  Battery life improvement freelectro 10 5,970 06-01-2023, 08:27 PM
  USB-C connector Overheated and melted nickbenjones 2 2,127 05-26-2023, 06:16 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 2,456 03-20-2023, 12:54 AM
Last Post: bcoyle
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 2,000 02-15-2023, 11:21 AM
Last Post: fxc
  Phone Dead Already? MarsColonist 4 3,806 08-11-2022, 11:52 AM
Last Post: auanta
  Power supply vs battery albafrati 11 6,937 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 2,109 04-28-2022, 12:45 PM
Last Post: james8880
