What's a good image to use now? [tutorial help as well]
Apparent antenna size doesn't directly correlate to signal strength. There are several factors. I don't even know what's inside that little dongle; it could perhaps be a nice fractal antenna. The internal antenna may work better outside the case. Mine (I have 3) might be ill-placed, cut to the wrong length, too close to certain metal objects. All of them are far too close to the bottom cover. The receivers and transmitters could be vastly different. Ever wonder why some cellphones outperform some laptops for connectivity?
There's nothing here like schöner Frankfurt Hauptbahnhof to compare; (and I am forbidden to return there to experiment). Also I'm not sure I ever tried any such "public" WiFi. I only use it at home, or tethered (by WiFi) to a phone. So it is perhaps different in other situations.
:wq
[ SRA accepts you ]
Having to use a dongle isn’t great for me. Would the steps for loading a new image remain the same?
I can write an image to a microSD card using Etcher, but I'm not sure what the next step should be. I've come across posts that mention flashing the storage drive, but I’m not familiar with how to do that. I’ve only installed an OS on a regular desktop and a 2009 MacBook Pro. https://modhello.com/
(01-09-2025, 09:54 PM)Der Geist der Maschine Wrote:
Quote:What's a good OS to put on it now?
The important question to ask: a) does suspend to mem work and b) do webbrowers as well as (some) video players decode in GPU.
I hadn't even thought to ask those questions to tell the truth.
  Pinebook Pro upgrading from the factory image yamsoup 12 4,794 02-22-2024, 04:02 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 2,751 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 134,365 08-24-2022, 02:06 PM
Last Post: petersen77
  Debian/unstable SD card rescue image vajak 4 4,923 10-28-2021, 02:53 PM
Last Post: vajak
Brick Anyone know of a good firewall? SpaceLord 6 7,231 07-24-2021, 12:04 PM
Last Post: globaltree
  Good i3 Config file to use? User 22018 6 7,315 06-17-2021, 09:38 AM
Last Post: user526
  Recalbox Image is available Luke 8 16,867 01-31-2021, 12:00 PM
Last Post: rimaille
  eMMC Trouble After Flashing WRONG Image balin 7 9,109 12-29-2020, 04:24 PM
  PBP not starting up sometimes / [Firmware Bug]: Kernel image misaligned at boot pato3 8 11,658 10-17-2020, 09:52 AM
  Pinebook Pro Sleep/Resume bug: The (Kinda sorta) Good, The Bad, and the (Very) Ugly. feoh 12 15,452 09-30-2020, 09:01 AM
Last Post: feoh
