OS Options for Pinetab2
So, I haven't really used my Pinetab2 much lately, because I have tried multiple times to install the stock image of danctnix and then update so that I can finally get Wi-Fi working to no avail. Is it a skill issue? Partly, sure. However, the image is so old that I imagine that it will be a challenge regardless.
I want an OS that will stay up to date so that I can use the device daily. I would prefer to get the experimental Wi-Fi driver running, despite the potential issues. However, it isn't a dealbreaker for me, since I do have a USB-C to ethernet adapter I can use to run updates when back at home.
I have 3 questions for the community:
1. For those using danctnix, has anyone had success with updating the stock KDE image? Or is there a different way you've gone about installing an up-to-date version of danctnix?
2. For those using Rhino Linux, how is the experience? And is the Wi-Fi driver available in the repos or pacstall?
3. For those using Ubuntu Touch, how is the experience? And is the Wi-Fi driver available somehow?
The wifi driver for Danctnix has been quite stable since it was included in the default kernel config. It should even be enabled in the "latest" img of danctnix (iirc correctly, it was added ~6.8 kernel.)
I haven't seen any reports on Rhino, but last I heard ubports is still very much under development and not ready for standard use. ubports does include a driver for the bes2600, but it's not exactly stable/useable
Try using the updated factory image from 3.5 months ago, should have the wifi preloaded:
https://echo.danctnix.org:7269/factory_i.../20240625/
  auto-owning the SD card in DanctNIX (Pinetab2) biketool 0 263 10-09-2025, 05:55 AM
Sad USB Gadget on PineTab2 Tronar 0 2,565 09-26-2025, 12:42 PM
Last Post: Tronar
  pinetab2 danctnix broken during upgrade - shell error acruhl 6 9,873 07-23-2025, 06:27 PM
Last Post: acruhl
  PineTab2 corrupted EMMC explit 6 5,538 09-13-2024, 09:09 AM
Last Post: Evergreen
  Cannot get into Pinetab2 joespodie 1 1,501 09-02-2024, 11:52 AM
Video Pinetab2 camera drivers cringeops 9 6,487 03-18-2024, 11:40 AM
Last Post: cringeops
  eMMC backup - pinetab2 pinetar.gz 0 1,794 01-07-2024, 09:08 PM
Last Post: pinetar.gz
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 8,014 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Touch doesnt rotate on Sway in PineTab2 cgbarros 4 5,971 08-03-2023, 05:49 PM
Last Post: cgbarros
  Disabling PineTab2 physical keyboard and touchpad? johns 7 5,218 08-03-2023, 11:55 AM
Last Post: cgbarros
Users browsing this thread:
