Touchscreen has stopped working
I have been using and loving my PineTime for almost 2 years, and it has suddenly developed a hardware issue. The touchscreen will not respond to touch, and the battery drain has gone from 16 days on a single charge to 2 days. I have rebooted the PineTime twice, flashed it from 1.13 to 1.14, allowed it to drain completely to shut it off, and nothing has helped. I'm not sure what could have caused this, I didn't drop or hit or soak it, from the battery drain it looks like it started at 5am when I was sleeping. Is there a way to repair it? All the other functions such as the step counter, bluetooth pairing, the physical button, notifications display etc all work.
Video:
https://imgur.com/Y7MA8Xq
Gadgetbridge showing it started at about 5am:
https://i.imgur.com/evRUXXr.jpeg
I ordered two back in the day thinking my other half would want one, he did not. It sat in its box for years and I finally pulled it out recently when my original watch started doing exactly that. Now, ~6 months later, it's starting to exhibit the behavior that led up to the first one's touchscreen failing.
The first thing I notice is that some mornings when I wake up all the colors on the screen are inverted, then after a few times turning the screen on it goes black and won't respond for a while. After about 5-10 minutes it comes on to the Acorn logo but turned 90 degrees so the version number is right next to the button.
I let the watch battery drain till it's dead before plugging it back in. This worked on my first watch for a few months with this happening about once per week but eventually the touchscreen completely stopped responding like you experienced.
Kinda wondering if it isn't something in software as I've now had two watches purchased the same time do it even though one has only been in use recently for me?
  Swipes hardly recognized, is there a way to test touchscreen? Goffi 4 6,237 08-09-2021, 11:19 AM
Last Post: Goffi
