PinePhone Pro Black Screen
I flashed Arch Plasma to the emmc on my new PinePhone Pro (2024, just got in today). I used the Micro SD method and after reboot the LED turns solid green and sits at a black screen indefinitely. I have tried the RE method, flashing various images to several different micro SD cards, holding volume buttons while powering on, pretty much anything I could find online. No matter what I do it always sits at a black screen. Any help would be greatly appreciated.
(03-09-2024, 12:25 AM)CrimsenRaven Wrote: I flashed Arch Plasma to the emmc on my new PinePhone Pro (2024, just got in today). I used the Micro SD method and after reboot the LED turns solid green and sits at a black screen indefinitely. I have tried the RE method, flashing various images to several different micro SD cards, holding volume buttons while powering on, pretty much anything I could find online. No matter what I do it always sits at a black screen. Any help would be greatly appreciated.
 I was having the same problem yesterday after flashing pmOS to the emmc by the USB method. I reinstalled Tow-Boot (by microSD) and then it worked just fine.
There was a huge update to Plasma 6 earlier this month. The danctnix image may have gotten some packages updated as well (https://github.com/dreemurrs-embedded/Pi...h/releases most recent was on 3/08), but it seems to still use Plasma 5.27 (although I am running Plasma 6 on my PinePhone and it works beautifully- highly recommend to update to that when you can).
I personally had to redo the Tow-Boot instructions multiple times before I got it, so make sure to follow the volume button instructions + orders carefully.
I also just recently had an issue on both laptop and my PinePhone Pro (after updating both to Plasma 6) where the login screen was black, but I could see the mouse (on phone you will probably not see mouse cursor). If this is happening to you, you can confirm it by plugging in a keyboard to your phone, dropping to TTY (Ctrl+Alt+F3 etc), log in (default user is alarm, pass is 123456). If this works, then you are probably having the same issue I was (and many others from what I've read in other forums about this). Do
sudo pacman -S qt6-wayland
And reboot, it should work after that.
If that doesn't help, try the image from 9/25 from Danctnix.
  Pinephone pro replacement lcd screen Linuxuser3 0 192 04-27-2024, 05:42 AM
Last Post: Linuxuser3
Question Pinephone Pro for a Debian user? primesocial 2 270 04-15-2024, 03:01 AM
Last Post: zetabeta
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 0 565 03-20-2024, 01:45 AM
Last Post: ashoka232
  PinePhone Pro Review tmoj 2 824 03-14-2024, 07:14 AM
Last Post: tmoj
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 799 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,407 02-10-2024, 09:54 PM
  Average Joe review of Pinephone Pro (March 2023) alaraajavamma 6 10,537 01-06-2024, 11:32 AM
Last Post: mikehenson
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 928 01-02-2024, 09:08 AM
  Pinephone Pro Screen Protector jydoxcen 11 1,583 12-21-2023, 07:58 AM
Last Post: zetabeta
  Pinephone Pro does not start with RE button pressed c0ssan 10 5,544 09-28-2023, 09:21 AM
Last Post: R0bbi3Mack
