Bad replacement battery?
I ordered this replacement battery for my Pinebook Pro and it won't charge. The laptop will power on with the new battery, the OS correctly identifies when it's plugged in, but the charge light blinks red and the charger (USB-C or barrel) doesn't draw any discernible power from the wall. Charging works as expected with the old battery plugged back in.
I notice that the old battery has a white wire in the center of the connector, while the new one does not. The second suspect thing is that the new battery is 33g lighter than the old.
Any thoughts on this? Does this missing white wire indicate a problem was inevitable, or could I have just gotten a bad battery? I have sent a message to the seller but haven't heard back yet.
Thank you!
(02-16-2024, 08:39 PM)chris88233 Wrote: I ordered this replacement battery for my Pinebook Pro and it won't charge. The laptop will power on with the new battery, the OS correctly identifies when it's plugged in, but the charge light blinks red and the charger (USB-C or barrel) doesn't draw any discernible power from the wall. Charging works as expected with the old battery plugged back in.
Thank you!
Where you bought the replacement batter? The middle wire connect to a thermistor placed near (inside) battery pack. You need to connect to 10K Ohm resistor if lacking the thermistor,
Thank you!
I bought it from here: https://www.aliexpress.com/item/32999824216.html
I'll give the resistor a try. I still haven't heard from the seller and at this point I think experimenting is all I have left.
Thank you!
Thank you!
Thank you!
Pine Store recommend user get from this site: https://www.cdrtd.com/products/laptop-re...s-new.html that listed on PineBook Pro spare parts page: https://pine64.com/product/pinebook-and-...4-version/
It's be nice to be able to buy it directly from the Pine store. Even better if they offered a larger battery - there's certainly more than enough space to increase the battery size.
  Replacement main board for Developers mozes 11 9,527 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 1,659 11-14-2024, 10:05 PM
Last Post: Sb2024
  Keyswitch scissors replacement cmj 1 2,292 10-14-2024, 05:35 PM
  Lithium Battery Connector Franestra 0 2,156 04-02-2024, 01:52 AM
Last Post: Franestra
  Bypassing the Battery gilwood 0 2,192 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 3,476 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 5,280 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 5,402 09-26-2023, 01:08 AM
Last Post: david-lechner
  Battery drain when off srs5694 1 2,713 03-24-2023, 06:05 PM
  Replacement scissor switches (ANSI keyboard)? zackw 3 6,862 08-09-2021, 09:20 PM
