PinePhone Pro: Camera App very laggy
Hello all!
I have installed the stable version of Mobian on my new PinePhone Pro. (mobian-pinephonepro-phosh-12.0.img.gz)
Now I noticed that the Camera app is very slow. In the Softwares About I found "0.1.0-net.flyingpimonster.Camera". Is it possible that the camera app is not up to date? The project Camera stoped in 219 and called now Snapshot, right?
Have you an Idea to solve the problem? Do you use maybe another app for shooting images?
Cheers - Martin
(08-17-2023, 10:04 AM)Martin87 Wrote: Hello all!
Cheers - Martin
It is slow BUT will get faster as development has not long been working.
Bear in mind there are few PPP distros to yet crack this - Mobian is one.
With the original PP it was led in the Megapixel app
1 Now with Pinephone Pro (used to have Pinephone and Pinetab) cooking on Mobian - Seasoned Ubuntu user since 2007
2 Known to break things - often
3 Sometimes known to fix things then see 2 above
Cheers - Martin
Yes, the preinstalled Camera app is outdated; it was renamed to Snapshot, so you should install gnome-snapshot (or Megapixels, which is common on PinePhone) for better performance, though camera speed is still limited by drivers on the PinePhone Pro.
I installed the Camera app from flathub (using the Software app) and it works. The back camera image was inverted for me, but by compiling the 6.16 kernel I see that it's the right way around. Only problem is that there is no focus or exposure setting, and the photos are too dark. QR scanning kid of works but is also very slow/laggy.
  what stopped pinephone pro? heocb 1 1,182 01-14-2026, 09:56 AM
  PinePhone Pro discontinued teekay 9 12,854 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,153 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,420 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 4,087 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 2,860 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 2,879 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 1,935 06-26-2025, 11:47 AM
Last Post: zetabeta
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 15,042 03-13-2025, 08:40 PM
Last Post: pcb
  New PinePhone Pro. No sudo command or access to root password. DanNewman 4 4,228 03-01-2025, 06:38 PM
