ROCKPro64 Battery Power Supply
This is just a fancy "battery holder" ,, BTW that is best search term
I don't think aa batteries have 3-4Ah capacity
IOW, this is just 8.... 1.5V cells in series, no electronics at all
I picked up this 12V/8300mAh power bank on Amazon for $49, and can confirm that it powers up the RP64 with the included barrel-jack, but further testing is needed.
I could find no good information on the actual current use of the rockpro64, so here are measurements i made:
I built a 12V 3A power supply - mains transformer, not swithcing. The no-load output was 17V
power use:  ~17V input,  with fan installed USB keyboard +usb mouse, no network;  cheap digitech DVM
    initial early boot pre-X    0.3A fan off
    during boot to X            0.65A  fan running
    static X interface          0.4A        "
    open firefox                0.8A        "
USING 5V 2A switchmode plugpak = 5.2V :  boot fails  GPIO pin 2 is 4.5V (instead of 5V),  pin 1=3.3V - OK
Use bench power supply (linear regulated)  5.5V - boot fails
Use  bench power supply 6.0V: boot succeeds  with wired enet , fan running, emmc xfce4, USB key & mouse
              GPIO pin 2 is 5.2V ;   I did not measure pin 1 - it must be OK
               Current measured on Tektronix DVM:     during boot has 1.3A peak;
                                0.5A with peaks to 0.6A with idlle xfce4 display, no apps running
                                Starting Fifrefox:   peaks to 1.7A, static page display 0.6A
                              Real peak currents will exceed this briefly due to DVM averaging and read intervals
If you are not using add-on devices or the PCI interface it seems you can run on 6VDC.
  Powering two disks from RockPro64 some_pinephone_user 3 3,294 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,091 12-03-2024, 06:19 PM
Last Post: misha64
  Powering on the Rockpro64 JPT223 1 3,572 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  RP64 Won't Boot After Power Down ColPanic_ 10 17,504 06-27-2023, 07:31 AM
Last Post: dkebler
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 43,621 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 3,374 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 5,623 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 15,004 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 3,988 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  NAS Setup: Hdds PSU external power option Robotik 1 4,858 07-18-2022, 10:10 PM
Last Post: zer0sig
