Problem with USB 3.0 Type A
Hello everyone,
I have got problem with the USB 3.0 Type A
No information in dmesg or journalctl -f -u systemd-udevd about any devices in this USB port.
$lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 002: ID 258a:001e HAILUCK CO.,LTD USB KEYBOARD
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$lsusb -tv
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
|__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
ID 258a:001e
|__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
ID 258a:001e
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 6, If 0, Class=Vendor Specific Class, Driver=mt7601u, 480M
ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
I do not know if this could be hardware issue, OS (Manjaro) or anything else?
Thank you for advice and suggestions.
PS: I've just noticed this post with similar, possibly the same issues https://forum.manjaro.org/t/usb-port-bre...sue/139653
One of the nice things about this hardware is how easy it is to rule out software: Try a different operating system on micro SD card. Hopefully you don't have an issue with U-Boot preventing that.
:wq
What are you trying to connect? The PBP is a low power device and things like large external drives (storage/DVD/CD writers) will require a powered USB hub to function.
PinePhone, Pinebook Pro & PineTab2 owner.
I used just ordinary devices, keyboard, mouse, a small WiFi adapter, eth adapter etc. It used to work. I have installed postmarketOS and had the same issue, no USB available. Therefore I assume it is problem with the hardware.
Sorry, I can’t assist with PostmarketOS/Manjaro; I don’t use them, my PBP was only Manjaro the first boot up to check if the hardware was working.
With that said, I can usually use a <20gb pen-drive and a mouse fine on my PBP, (without the additional NVMe kit installed) utilizing the stock power adapter. Anything more than that and I need a powered hub.
Try a Debian based OS if you have the time, Kali & Debian have been reliable for me.
  Yet another new Pinebook keyboard problem MikoBob 3 854 09-11-2024, 07:05 AM
Last Post: MikoBob
  Curious about problem with PBP Wifi kendew 3 5,723 01-14-2021, 11:16 AM
Last Post: clover
  NVME problem chaoskampf 2 5,953 07-01-2020, 09:10 AM
Last Post: chaoskampf
  Problem with ESP32 connected to USB2. USB3 - seems OK. erikbotta 0 2,318 06-22-2020, 01:28 PM
Last Post: erikbotta
  keyboard problem romansvec 12 16,190 11-11-2019, 02:45 PM
Last Post: CryptoRick
