Pinetab2 not booting.
Upon arrival my pine tab 2 didn't boot.  So I flashed a SD card and tried booting via the UART adapter. I get the following message when using screen:
mmc1: error -110 whilst initializing mmc card
I've used probably 4 different SD cards.
The screen comes on but nothing displays. Any help would be appreciated. Thanks!
For some reason now I'm not getting any error messages with screen. The display remains blank.
(07-05-2023, 06:30 PM)elix Wrote: Upon arrival my pine tab 2 didn't boot.  So I flashed a SD card and tried booting via the UART adapter. I get the following message when using screen:
I did get that error, or something similar, once, trying to boot from an SD Card, but I did persevere. I tried installing Mobian, in the hope that Mobian had included a WiFi driver, but after installing, and shutting down, I was in the same position as you. Blank screen and no matter what I tried, it would not boot.
I've had more success though, than you, as I wrote danctnix-factory-image-20230527.img.xz to a well used 32gb SD Card, and using the instructions at "using the debug UART adapter" was able to rewrite the "factory image" successfully (no WiFi of course).
I do wonder if the mmc1 error is referring to your eMMC storage rather than the SD Card, as I found the UART adaptor quite tricky to use. You seem to have to switch at just the right moment.
PinePhone Beta 2GB/16GB Postmarket OS v23.06.1 Phosh 0.30.0 (not in use)
PineTab2 Arch Danctnix 6.4.2
Yea I'm using that image. Its just really puzzling because now I'm not getting ANY output in screen.
Are either of you able to connect an external display via HDMI?
There are others with a blank screens, but the device is still booting.
No I haven't. This may be a stupid question but what type of HDMI adapter will I need?
(07-07-2023, 04:30 PM)elix Wrote: No I haven't. This may be a stupid question but what type of HDMI adapter will I need?
A micro HDMI to HDMI adapter should do.
Please refer to the wiki: https://wiki.pine64.org/wiki/PineTab2
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
I have. Many times.
(07-07-2023, 12:20 PM)Purple_Illusion Wrote: Are either of you able to connect an external display via HDMI?
I thought I had replied to this but cannot see it.
A Pi4 HDMI cable should work as it is a micro HDMI to HDMI cable. [Image: 23y-ptab2-ext-disp.jpg]
However, it didn't work in my case although the PTab2 reported that it was connected to an external display and allowed me to switch between various modes, but nothing appeared on the external screen.
There is a discussion on going at Pinetab 2 screen no longer coming on.
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 231 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 400 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 866 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 739 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,430 09-25-2023, 08:29 PM
Last Post: bluemage
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,004 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,135 08-23-2023, 09:38 AM
Last Post: diederik
  pinetab 2 not booting ajhiii070 5 1,928 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,234 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2 virtual keyboard: symbols instead of numbers clemfandango 5 2,073 07-12-2023, 05:32 AM
Last Post: mtomaschett
