how to disable ipv6 at kernel level with towboot?
Adding  U_BOOT_PARAMETERS="ipv6.disable=1"   to /etc/default/u-boot        and run  u-boot-update use to work before tow boot.   What is the new methodology to pass  ipv6.disable=1 to kernel ?
(06-19-2023, 03:13 PM)vusra Wrote: Adding  U_BOOT_PARAMETERS="ipv6.disable=1"   to /etc/default/u-boot        and run  u-boot-update use to work before tow boot.   What is the new methodology to pass  ipv6.disable=1 to kernel ?
i cannot be certain about kernel parameters with bootloader, but syntax should be same, just inserting the string input is little different, probably different place.
however, you could try sysctl.conf, this happens during boot of course, so it's not immediate.
# location: /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6=1
net.ipv6.conf.default.disable_ipv6=1
superior method    is  edit /usr/share/u-boot-menu/conf.d/mobian.conf
change line
U_BOOT_PARAMETERS="consoleblank=0 loglevel=7 ro quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=0"
to
U_BOOT_PARAMETERS="consoleblank=0 loglevel=7 ro quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=0 ipv6.disable=1"
and run
sudo u-boot-update
edits to /usr/share/u-boot-menu/conf.d/mobian.conf can be undone in future rupdates
How do we perform this in a separate conf.d file to obviate overwrites when /usr/share/u-boot-menu/conf.d/mobian.conf is updated by package manager?
  Disable vibrations 3x5co 9 15,005 01-03-2026, 12:26 PM
Last Post: baptx
Big Grin An early xmas present: 6.1 kernel treebeard 28 28,579 07-18-2023, 03:14 AM
Last Post: gischpelino
  Stability problems with 6.1 kernel Zebulon Walton 9 9,571 05-12-2023, 08:09 AM
Last Post: zetabeta
  How to enable ipv6 for hotspot robgadget 1 2,868 04-28-2023, 06:59 AM
Last Post: wibble
  Disable headphone controls 3x5co 0 2,039 09-10-2022, 07:11 AM
Last Post: 3x5co
  Disable *automatic* on-screen keyboard iwakura_lain 0 2,650 06-11-2022, 09:49 AM
Last Post: iwakura_lain
  Disable on screen keyboard permanently. grump_fiddle_reinstall 12 20,998 06-11-2022, 08:11 AM
Last Post: SwordfishII
  Hotspot and IPv6 gosh000 1 2,759 06-08-2022, 02:12 AM
Last Post: wibble
  Kernel 5.15 Zebulon Walton 10 13,529 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 7,959 11-10-2021, 01:22 PM
Last Post: user641
