PineTab2 power options
I have one other question for the group. I'm finding it difficult to turn the screen off without powering it down. I have changed the settings to use the power button to turn the screen off in while on battery and wired but it appears to do nothing.
Is anyone else having this issue or is it a known issue? I've tried everything but nothing is working. Any advice would be much appreciated. Thank you in advance!
When I close mine on the desk and leave it closed for a few seconds, the screen turns off & I haven't changed anything regarding power.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
Yes, "suspend" isn't working yet, so the best we can do is turn off the screen or shut down the device.
System Settings -> Power Management -> On Battery lets you adjust the time to screen dimming and off. I have found the default settings pretty suitable.
Side notes:
1. Locking the screen (Pine - L) seems to hamper the dimming, though it still turns the screen off after a while.
2. When the device has been shut down, it boots back up when plugged in to power. So I've been trying to plug it in *before* shutting it down.
Thanks for the replies! Very helpful information as always!
  New PineTab2 dRateNWAytORy 2 149 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 251 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 432 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 897 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 766 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,484 09-25-2023, 08:29 PM
Last Post: bluemage
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,038 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,190 08-23-2023, 09:38 AM
Last Post: diederik
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,309 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2 virtual keyboard: symbols instead of numbers clemfandango 5 2,119 07-12-2023, 05:32 AM
Last Post: mtomaschett
