PineTab2 power options
I have one other question for the group. I'm finding it difficult to turn the screen off without powering it down. I have changed the settings to use the power button to turn the screen off in while on battery and wired but it appears to do nothing.
Is anyone else having this issue or is it a known issue? I've tried everything but nothing is working. Any advice would be much appreciated. Thank you in advance!
When I close mine on the desk and leave it closed for a few seconds, the screen turns off & I haven't changed anything regarding power.
PinePhone, Pinebook Pro & PineTab2 owner.
Yes, "suspend" isn't working yet, so the best we can do is turn off the screen or shut down the device.
System Settings -> Power Management -> On Battery lets you adjust the time to screen dimming and off. I have found the default settings pretty suitable.
Side notes:
1. Locking the screen (Pine - L) seems to hamper the dimming, though it still turns the screen off after a while.
2. When the device has been shut down, it boots back up when plugged in to power. So I've been trying to plug it in *before* shutting it down.
Thanks for the replies! Very helpful information as always!
  No updates on pinetab2 arch danctnix? Ingen 8 797 10-16-2025, 02:57 AM
Last Post: TcCoy
  Libre Office on Pinetab2? Anonymous1989 1 691 08-07-2025, 09:50 PM
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 4 4,702 05-31-2025, 02:34 PM
Last Post: stevepaesani
  New pinetab2 - can't charge it tmhorne 10 4,795 05-13-2025, 12:42 PM
Last Post: tmhorne
  PInetab2, Limit battery charge to less than 100%? rqkeating 0 1,637 06-30-2024, 08:54 PM
Last Post: rqkeating
  New PineTab2 dRateNWAytORy 2 3,070 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 1,774 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 3,036 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 2,823 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 2,666 11-05-2023, 10:20 AM
Last Post: WEF
