Emergency Mode Boot Hotkey?
#21
Not all have reported success, myself, well I didn't have to take off back
I tried V1 to see how it compared vis a vis mrfixit BSP uboot for STR, sleep to ram
About 1/2 as good, ie ~ 7d
So I tried V2 (to see if it might be better), and got no boot
All this with tow-boot on sd, emmc 1st 16 blank except mbr ( and installed distro 32768 ->)
So, just a question of changing sd or writing a different one to it (to recover)
IIRR I then went back to V1 just to check, then V2
So, all tow-boot versions are not equal
Be aware the tow-boot for sd/emmc writes a gpt boot record and ignores any previous partitions,
you will have to fix this if there is anything on the sd
  Boot Order in Pinebook Pro food 11 12,082 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,224 08-21-2024, 04:17 AM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,561 12-11-2023, 03:47 AM
Last Post: calinb
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 5,427 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Tow Boot install help Paulie420 7 9,337 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 4,777 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 2,669 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 9,917 08-18-2022, 11:47 AM
Last Post: Bemo
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 23,509 05-12-2022, 05:00 AM
Last Post: Pino64
  Broken eMMC boot annahellrothsparent 3 5,722 04-28-2022, 07:31 AM
