Boot Ox64 after SPI Flash IC replacement
Hi!
I bought 16 Mb version of Ox64 (128 Mb one was out of stock) and replaced SPI Flash IC with bigger one (128 Mb) and add MicroSD slot too.
Is there any way to download the initial firmware to Flash and boot as usual to use BLDevCube for further operations?
Many thanks!
With regards,
Maksim
I see, the only solution is to retrack the Flash IC and burn firmware to it with an external programmer.
Please share the firmware binary, if possible.
Many thanks!
With regards,
Maksim
  Star64: All listed distros don't boot tantamount 0 72 05-08-2026, 08:56 AM
Last Post: tantamount
Sad PINETAB-V doesn't boot. FEC 1 2,788 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 5,541 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  Ox64 Without Dev Cube? segaloco 2 3,360 05-12-2024, 10:46 PM
Last Post: donadams
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 2,647 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Star64 first boot (and success) bortzmeyer 1 4,193 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 3,011 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  How to boot from SD card on pinebook pro linux123 3 9,496 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 5,113 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 3,375 10-18-2020, 01:41 PM
Last Post: toiny
