Broke Screen and fix it - Up Swipe not working.
Dropped it on the corner and broke the screen.
Replaced it and the "slide up to unlock" is not working now (will not slide up!).
Any suggestion or recommendations?
As in you mean only touchscreen is not working after screen replacement?
Take it apart, look for damage and reseat / reattach ribbon cables once again.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
(02-11-2023, 11:47 PM)RTP Wrote: As in you mean only touchscreen is not working after screen replacement?
No touchscreen... Re-did as you recommended.  Nothing is working as far as touchscreen is concerned.  Re-flashed to latest Plasma Mobile image, still nothing.   Will try w. Phosh image but not expecting much.  Maybe the drop broke something HW wise?
**----> Didn't work!!! Going to take it apart again. I Ordered a new ribbon cable (hoping!)... If that doesn't work then probably HW issue.
**Note - If anyone knows anything about touchscreen diagnostics...feel free to chime in.
**> Still awaiting parts to arrive.
&&& - > Part came in...still no luck! Does anyone know anything about touchscreen diagnostics!! Next step is to send the screen back.
  2024 Sep 21 - PinePhonePro Calls Working mikehenson 9 8,620 01-19-2025, 11:47 AM
Last Post: giorez
  PinePhone Pro Black Screen CrimsenRaven 3 3,725 11-13-2024, 09:33 PM
Last Post: twentyslimy
  A way to view or log the splash screen on Pinephone Pro running ArchLinux (Danctnix) PHLEMON 4 3,771 07-30-2024, 11:03 PM
Last Post: PHLEMON
  Camera stops working after resume from suspend jchw 3 3,338 07-30-2024, 05:52 AM
Last Post: DrYak
  Pinephone pro replacement lcd screen Linuxuser3 0 1,824 04-27-2024, 05:42 AM
Last Post: Linuxuser3
  Pinephone Pro Screen Protector jydoxcen 11 6,827 12-21-2023, 07:58 AM
Last Post: zetabeta
Thumbs Up PinePhone Pro working adamfowleruk 2 4,305 02-16-2023, 06:47 AM
Last Post: Piotr
  Broke my screen Barugon 7 7,552 10-11-2022, 01:30 PM
Last Post: Juan_Mann
  SMS Receive suddenly stopped working grinzie 6 6,672 10-01-2022, 12:44 PM
Last Post: grinzie
  Internet is not working on Pine Pro phone caroljames972022 0 1,795 09-16-2022, 06:25 AM
Last Post: caroljames972022
