experience: pinephone keyboard drains pp battery faster?
Hi
i've had some weirdness with my pinephone keyboard. (might be my fault but just reporting/checking)
and i don't know if its because i did something wrong or something else.
Here is my experience:
with the keyboard attached the battery drains faster then without.
-without the keyboard my pp is still alive after a nights sleep
-with it's usually almost dead, the main battery completely drained and the keyboard battery very low
other things:
-the charging seems very slow through the keyboard
-pp also seems to run hotter more often with the keyboard attached (warmer to the touch then normal)
Now i have to admit, when i got the keyboard i was excited and hooked it to the pp and attached the dock + charger via the pp's usb-c (yup didn't read the manual lol)
Not sure if that is what caused this. but it could be.
has anybody else had this experience? is there a way to verify that i messed up the hardware? or any fixes?
thanks!
Unfortunately your keyboard's charging circuit has probably died. It's happened to quite a few of us if you look around the forum: https://forum.pine64.org/showthread.php?tid=16271
To test or fix the hardware you'd need to be good with a multimeter and soldering iron. I'd been thinking about buying a small charge controller circuit to try and repair mine but I don't have the time at the moment.
As my keyboard is definitely broken, I admit I now do charge through the phone's USB-C port, but do that at your own risk and I wouldn't leave it unsupervised in case the keyboard circuit overheats. My keyboard battery never charges up anymore but it still works as a keyboard when the phone is charged.
(02-11-2023, 12:39 PM)acid andy Wrote: Unfortunately your keyboard's charging circuit has probably died. It's happened to quite a few of us if you look around the forum: https://forum.pine64.org/showthread.php?tid=16271
Taking the keyboard apart, you can unscrew the board to take a look to see if the chip appears fried.
If so, you can find replacement keyboard mainboards for $9.99: https://pine64.com/product/pinephonepro-...mainboard/
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
  Pinephone (Pro) Keyboard Case for sale manubert 3 13,073 08-26-2025, 06:06 AM
Last Post: zetabeta
  Replacement battery for PinePhone? j_s 9 4,679 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 18,507 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 3,514 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 14,100 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 0 2,221 07-19-2024, 08:02 AM
  Keyboards for the PinePhone? Peter Gamma 1 3,140 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 3,402 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 1,863 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 3,065 06-29-2024, 09:36 PM
