No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED
I think the title says it all. I tried to upgrade from the CLI, and when I tried to reboot, the phone won't. Furthermore: I tried connecting to my computer, then turning on the phone with the volume up button help down. The LED turns blue, indicating it's in mass storage mode, but the computer doesn't see it.
Also, I flashed the most recent installer, and pre-built image, to SD cards, but them in the phone, and neither are seen by the phone.
A semi-update: I learned from the tow-boot documentation that the Pinephone will not automatically load from an SD card unless you hold the volume button down while holding the power button. When I did this, I was able to boot from the installer SD. I'll leave this thread open in case someone has a specific solution to the issue of Mobian not booting. For my purposes, it was enough to re-install.
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,710 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Command to test vibration motor? Zebulon Walton 3 1,971 11-12-2023, 08:45 PM
Last Post: zetabeta
  How to check if tow-boot is installed? jojuma 3 804 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 580 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 771 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,246 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 902 03-06-2023, 12:06 PM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,057 03-01-2023, 04:45 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 3,765 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 960 01-13-2023, 03:33 AM
Last Post: mdk
