Pinephone lost graphic during mobian system upgrade
Wink
I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
(10-18-2022, 12:55 AM)cmpin Wrote: I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
Do you get the decypt password question before black screen?
Is it the same problem than mine?
https://forum.pine64.org/showthread.php?tid=17899
(02-28-2023, 12:40 PM)anonymous Wrote: Is it the same problem than mine?
Mine new install does the same as yours. I had to reinstall last year due to upgrade stopping the system even booting. Just got red led flash and haptic for 5sec and then it turned off.
Have you tried to reinstall, disable greetd and re-enable phosh before upgrading like I did?
  Mobian image for the PinePhone Korfou 2 740 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 58,219 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 67,854 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,754 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 318,220 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,469 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,324 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,934 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,765 04-29-2025, 02:10 PM
Last Post: mdk
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 4,969 02-21-2025, 07:25 AM
Last Post: dragonhospital
