07-13-2016, 07:22 PM
is the camera module supposed to fit into the slot in the lcd panel? it's a bit big, and does not fit. see picture.
https://imgur.com/uiJQq5s
![[Image: uiJQq5s.jpg]](http://i.imgur.com/uiJQq5s.jpg)
camera module and lcd integration
https://imgur.com/uiJQq5s ![]()
07-13-2016, 11:45 PM
This may take some creative 'maker' DIY ingenuinty.
I don't have mine yet, so I have not played around with it... but I know that there is only one camera module supported at this moment. The Raspberry PI camera WILL NOT work. The opening may need to be altered with a dremel/ can't say anything too specific atm. marcus
08-07-2016, 02:10 PM
(This post was last modified: 08-07-2016, 02:17 PM by blackt1ger.)
(07-13-2016, 07:22 PM)jodybrown99 Wrote: is the camera module supposed to fit into the slot in the lcd panel? it's a bit big, and does not fit. see picture. Yeah, same here. Absolutely crazy. Wait till you try to mount the LCD in the playbox enclosure. The cables aren't long enough. The sensor is 8.5 mm and the hole is 6.7...... ![]()
08-07-2016, 02:39 PM
Yeah, sadly, tllim says the enclosure was designed for the smaller camera, not the 5mp camera.
marcushh777
![]() please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! )
09-01-2016, 01:31 PM
Absolutely genius. :-(
10-11-2016, 11:35 AM
Came here expecting to be disappointed, everything worked out as anticipated. XD
Marks's dremel idea is probably the best option. Now, to make it work without damaging anything... |
CSI / Camera Module Compatibility? | vade | 8 | 6,815 |
04-03-2020, 05:39 AM Last Post: Ellesar Dragon |
13MP Camera cable extension | saviod | 2 | 1,250 |
06-21-2019, 06:05 AM Last Post: saviod |
Camera | Sasank | 15 | 9,981 |
12-13-2018, 09:08 PM Last Post: Mutani |
Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel | themyshop | 3 | 2,065 |
05-10-2018, 04:28 PM Last Post: tllim |
Webcam vs camera module on pine64+ | fkpkot | 4 | 3,706 |
02-27-2017, 03:57 PM Last Post: MarkHaysHarris777 |
Camera is working on Linux | @lex | 50 | 24,669 |
10-26-2016, 03:17 PM Last Post: @lex |
camera port details? | gourmand007 | 5 | 4,098 |
07-09-2016, 12:24 AM Last Post: peteforde |
About the camera | robopo | 10 | 8,192 |
06-28-2016, 03:42 PM Last Post: Pander |
Anyone get the camera to work yet? | Havensal | 15 | 8,309 |
06-28-2016, 03:37 PM Last Post: Pander |
