Is some u-boot required on the SPI for installing debian with the official installer?
https://wiki.pine64.org/wiki/ROCKPro64_Software_Release reports the possibility of installing debian on the ROCKPro64 using the Official Debian Installer via the installer image to be found at https://deb.debian.org/debian/dists/bull...rd-images/
I have verified that the installer image boots and does its job of downloading and installing stuff.  However, installing (at least installing on the EMMC) delivers a system incapable of booting.
I now wonder if this is because the official debian installer does not install a bootloader and expects a bootloader to be already present on the SPI.
If this is the case, the page at https://wiki.pine64.org/wiki/ROCKPro64_Software_Release shouild probably say so.
I have tried to install tow-boot on the SPI expecting it to be the best option for a general bootloader.  Unfortunately, It does not appear to work. After coming up, it hangs at
Booting using the fdt blob at 0x1f00000
It is unclear to me if this is a bug in tow-boot (also looking at https://github.com/Tow-Boot/Tow-Boot/issues/186).
If it is, what would be an appropriate uboot for running debian?
i had exactly the same problem you describe. Following the guide at https://github.com/sigmaris/u-boot/wiki/...oot-to-SPI with the SPI Image from https://github.com/sigmaris/u-boot/relea...spi.img.gz worked for me. It seems that the wiki should be updated, that updating the spi might help to resolve boot problems.
I hope updating the SPI to that version helps you too. I didn't need to reinstall debian to my emmc, it just worked after inserting it back after updating the SPI.
best wishes
  Boot/Shutdown on timer captainmorgan 8 6,116 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,649 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,501 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,320 07-14-2023, 04:22 AM
Last Post: hunderteins
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 1,137 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 566 04-23-2023, 11:02 PM
Last Post: Thisone
  RockPro64 boot questions misterc 3 1,599 01-13-2023, 06:21 PM
Last Post: misterc
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,439 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 2,594 01-06-2022, 03:09 AM
Last Post: susy1075
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,302 01-03-2022, 10:32 AM
Last Post: whitecat23
