No boot after Manjaro flash
@bburdette
mtd (memory technology device),,, it is not so clear,
Did you write or install something OR just try to boot?
If just boot, try hard reset (hold pwr button 20+ sec)
and obviously SD card out
(09-27-2022, 08:52 AM)wdt Wrote: @bburdette
Ah yes, mtd.  No I wanted to try writing to that with nandwrite but the device wasn't visible in the old version of manjaro.  So I attempted booting from new manjaro on SD, and that apparently bricked the pinebook.  So I never got to try writing to mtd0.
I won't be able to try the 20 seconds trick till Friday, but thx.
Holding the power button down for 20 seconds doesn't do anything.  No leds, no nothing.
Try removing the EMMC card and putting it on the USB adapter and boot from that using tow boot. That was the only way I could boot Manjaro-ARM-kde-plasma-generic-22.08.img. Obviously not a solution but debug step.
I can't figure out if tow boot or Manjaro is the issue though as the issue only happened after the Manjaro update but tow-boot shows GPT partition errors that I think mean it can't find the GPT partition. When I put the EMMC card on the USB adapter and boot from that it can find the partition just fine and boot.
@bburdette
After the hard reset, you have to try and start it the normal way, ~1s press
Just if you didn't understand
gdisk has a v = verify command
in the recovery menu = r you could try g = convert to MBR only OR f = rebuild GPT from MBR
(only if MBR and GPT match partition count numbers, o MBR and p GPT in recovery menu)
or there may be other problems that verify will tell you about, maybe the backup is not at end of disk
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 424 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 898 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 22,033 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 14,045 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 10,477 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,448 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,535 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,030 09-04-2024, 10:35 AM
  Manjaro versions bad and good gilwood 0 2,116 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 6,950 01-19-2024, 02:29 PM
