Pinetime Screen issue after bootloop troubles
(09-15-2022, 05:40 AM)wibble Wrote: The heart rate sensor window is clear plastic, stuck to the back cover. Depending on how well I align it when I put the back cover on it sometimes looks like there's some pressure on the back, raising the middle of the window slightly. It's seem most easily if you view at an angle to see the distortion of the reflection on the window. I could imagine this leading to a leak over time. Since I stuck the back on myself I've assumed it will leak, but between sweat and rain it's been ok so far.
I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
The erosion definitely looks as if it came through the area where there is the heart rate window. The rest of the PCB looks corrosion free.
It still may not explain the display though.
@Spater How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
Thanks @wibble for looking into the assembly of the heart rate sensor and case fitting.
Quote:I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
@barray you are right, I have the Sealed version of Pinetime.
Quote:How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
I used pure Isopropyl alcohol to clean it.
Quote:It still may not explain the display though.
Took a look at the back of screen, could the spot in the red circle (see attached picture) be due to some kind of overheating?
Looks like there's something on the back of the board in the same location, but it's out of focus. What is it?
  Bluetooth Connection Issue Orionbelt 2 1,525 11-24-2023, 05:27 PM
Last Post: BrianPineFan
  PineTime and Amazfish on Ubuntu Touch jmlich 1 279 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 12,332 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 10,411 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 817 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 5,437 02-11-2023, 09:30 AM
Last Post: alexmitroff
  Screen stopped working properly pcfreak9000 3 1,119 01-18-2023, 04:28 PM
  PineTime beginner MV1791 2 1,636 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 841 11-20-2022, 11:06 PM
Last Post: John45595
  PineTime Dev Kit for sale igor.bljahhin 2 2,755 10-19-2022, 05:34 AM
Last Post: peatord
