Battery problem with a Pinephone keyboard and Mobian
I have a Pinophone equipped with the Pinephone keyboard (operating system: Mobian).
As indicated in the instructions, to recharge the Pinephone, I plug the usb cable from the charger into the usb input on the keyboard.
Until a recent update, with Mobian, once the battery was charged, the charge indicator showed 200%. It seemed a little strange to me, but considering that with the keyboard battery, the device has two batteries (keyboard battery + Pinephone battery), there is a logic to the matter… and there was no problem. My Pinephone had a battery life of about two days.
But since a recent update, things have changed:
I can still charge the Pinephone by plugging the usb cable into the keyboard input, but it seems that mobian no longer detects the keyboard battery.
After charging for a whole night, the charge indicator in mobian only shows 65% maximum. Also the keyboard battery doesn't seem to charge the Pinephone battery Undecided
Result: the autonomy of my pinephone went down to about ten hours!
Does anyone have a clue to help me?
Thanks Smile
I am using Manajro ARM (Phosh) and I have the same problem.
Quote:uname -r
Linux manjaro-arm 6.0.2-1-MANJARO-ARM #1 SMP PREEMPT Wed Oct 19 06:43:45 UTC 2022 aarch64 GNU/Linux
Previously, it used to show 66% on a full charge,
but after updating to the latest version, it shows 33% on a full charge.
Perhaps the latest version of Mobian (Weekly) will also show 33% on a full charge.
I do not know how to correct the problem.
I wish I had a better solution....
Quote:cat /sys/class/power_supply/ip5xxx-battery/uevent
     1  POWER_SUPPLY_NAME=ip5xxx-battery
     2  POWER_SUPPLY_TYPE=Battery
     3  POWER_SUPPLY_STATUS=Not charging
     4  POWER_SUPPLY_CHARGE_TYPE=N/A
     5  POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
     6  POWER_SUPPLY_HEALTH=Safety timer expire
     7  POWER_SUPPLY_CAPACITY=86
     8  POWER_SUPPLY_CALIBRATE=187
     9  POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
    10  POWER_SUPPLY_VOLTAGE_NOW=4016064
    11  POWER_SUPPLY_VOLTAGE_OCV=4166452
    12  POWER_SUPPLY_CURRENT_NOW=-7460
    13  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=2300000
    14  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=3100000
    15  POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE=4228000
    16  POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE_MAX=4242000
Quote:cat /sys/class/power_supply/axp20x-battery/uevent
     1  POWER_SUPPLY_NAME=axp20x-battery
     3  POWER_SUPPLY_PRESENT=1
     4  POWER_SUPPLY_ONLINE=1
     5  POWER_SUPPLY_STATUS=Charging
     6  POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
     7  POWER_SUPPLY_VOLTAGE_NOW=4249000
     8  POWER_SUPPLY_CURRENT_NOW=270000
     9  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=1200000
    10  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=1200000
    11  POWER_SUPPLY_HEALTH=Good
    12  POWER_SUPPLY_VOLTAGE_OCV=4194300
    13  POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
    14  POWER_SUPPLY_VOLTAGE_MIN_DESIGN=3000000
    15  POWER_SUPPLY_CAPACITY=99
The image below shows the PinePhone (+ PP Keyboard) almost fully charged.
(10-28-2022, 02:24 PM)presire Wrote: Previously, it used to show 66% on a full charge,
For me, on Mobian and PostmarketOS it's started displaying 25% on a full charge.
My current theory is it's due to changes in how the UPower daemon calculates the display percentage. Have a look at my thread about it:
https://forum.pine64.org/showthread.php?tid=17740
  Upgrade to Mobian (Trixie) Staging biketool 11 369 9 hours ago
  how to update mobian over tor vusra 14 9,169 12-04-2024, 07:01 PM
Last Post: vusra
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 3 874 12-04-2024, 09:53 AM
Last Post: zetabeta
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 41 8,647 11-27-2024, 10:39 AM
Last Post: fernando_c_m
  atinout binaries for mobian/debian? NeutralGrey 4 1,393 10-31-2024, 04:16 AM
Last Post: astylethargic
  Mobian-Kicksecure? 3460p 0 852 05-26-2024, 02:09 PM
Last Post: 3460p
  Mobian repository status henrythemouse 16 12,166 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 909 03-18-2024, 08:54 PM
Last Post: penguins_rule
  icon keyboard chris_02 3 1,533 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard not popping up on QT apps 3x5co 1 1,070 02-08-2024, 11:45 PM
