Rock64 Debian 11 (Bullseye) install problem
Lightbulb
For all of you who struggle to install Debian onto your Rock64, I've made a how to guide for this.
A pdf for downloading and safe keeping / later use is in that repo as well.
@ju0n this is a revised version which just uses the images and u-boot directly from Debian.
Awesome!
Thanks a lot
(12-11-2022, 08:31 AM)as365n4 Wrote: For all of you who struggle to install Debian onto your Rock64, I've made a how to guide for this.
Are we saying, then, the posted instructions have a major flaw?
(02-24-2023, 06:17 PM)Flagtrax Wrote: Are we saying, then,  the posted instructions have a major flaw?
I would not say major flaw, but software matures and evolves over time. ;-)
And using the Debian Installer is the most efficient way right now, even though it can't install u-boot for some reason.
I think there was some intention to point this out on the wiki:
"Remember to leave some space before your first partition for u-boot! You can do this by creating a 32M size unused partition at the start of the device."
But it's unclear when or how to do that, simply performing manual partitioning in the (bookworm) installer, and leaving the initial fat partition alone is enough for the debian installer to work as expected. When I can figure out how to reset my wiki password I'll try to tweak that assuming no one else does first.
  Rock64 - not booting after Armbian update helpmerock 6 1,249 03-27-2025, 08:26 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 8 2,966 01-25-2025, 12:57 PM
  can rock64 4gb ram run entirely on free software? heocb 1 679 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 747 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 5,068 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 544 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
  arch rock64 does not boot nemnob 1 1,682 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 57,097 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 90,856 09-01-2024, 06:05 AM
  How to update/compile Debian 12.5? Wizardknight 3 2,272 03-29-2024, 05:01 AM
Last Post: gedas07
