PinePhone Pro not detected by my PC
#21
You need to hold volume down button immediately after powering on and seeing the red light + first vibrate. That'll boot to the sd card.
I'd also like to see the output of
lsblk
and your dd command being issued.
[/quote]
To illustrate my edit of my last point I waited for a minute to press enter to show you the status of the installation. It won't install if the inter button is not consistently being pressed.
What did I do wrong here?
https://imgur.com/Qne62oo
Edit: is it that i should type mmcblk1? not mmblk1?
I did try it with mmcblk1 in lieu of mmblk1 and there was no difference still wont install unless i hold the enter key
[/quote]
  PinePhone Pro: Camera App very laggy Martin87 3 4,026 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 5,709 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 1,662 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 1,325 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 2,132 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 1,508 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 1,497 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 1,114 06-26-2025, 11:47 AM
Last Post: zetabeta
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 11,838 03-13-2025, 08:40 PM
Last Post: pcb
  New PinePhone Pro. No sudo command or access to root password. DanNewman 4 2,655 03-01-2025, 06:38 PM
