Tow-boot required to new installations
I was just reading the news regarding tow-boot; https://wiki.mobian-project.org/doku.php...tall-linux
Once there's a new tow-boot release, do we need to reflash tow-boot and reflash mobian again every time?
Once I install tow-boot, can I reflash the mobian image with installer from april 3th? Or should we wait for new images?
It looks interesting and I like the idea of being able to get Jumpdrive functionality without having to use a separate SD card for that. The issues mentioned though (periodic boot failure and failure to resume from suspend) seem annoying, though presumably those will be fixed in a future release. More importantly it's not clear what affect (if any) installing this will have on Mobian already installed on the eMMC - do you have to reflash your OS after installing or updating tow-boot?
(04-09-2022, 07:48 AM)Zebulon Walton Wrote: The issues mentioned though (periodic boot failure and failure to resume from suspend) seem annoying, though presumably those will be fixed in a future release.
The issues are soley for  Pro version?
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,712 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 804 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 580 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 771 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,248 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 902 03-06-2023, 12:06 PM
Last Post: freelectro
  boot gets stuck shortly after disk decryption vortex 8 3,767 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 960 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 922 01-04-2023, 06:46 PM
Last Post: 3x5co
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 2,543 12-31-2022, 10:56 AM
Last Post: DrPlamsa
