Calls don't work on Softbank. Cellular data & SMS work.
From the sxmo dialer, calling 111 (Japan's test dial) does nothing for a while, then I get "missed call 111" and a "QMI Protocol Error: IncompatibleState".
From the `dev/ttyUSB2` terminal, `ATD111` just says "NO SERVICE".
phone: Pinephone OG 2gb.
image: PMOS SXMO installer one on SD card.
carrier: Y!mobile (Softbank under the hood)
ModemManager log: https://pastebin.com/vKgk2YCr
(pastebin set to 2 week exipiry. I stripped the timestamps and excessive `<<<<<<` to make it fit into 512kb but I just realized this forum takes 32MB attatchments. wow.)
(I really hope I'm not exposing my phone number in a non-human-readable way. I removed the ones that I found.)
Seems like the paste was removed by pastebin. And the forum attach does not take 470ish kb txt files.
Is there a section of the log that would be useful to share?
Skimming through it, I see there are three "verbose call end reasons":
<info>   [modem0/bearer1] verbose call end reason (2,210): [internal] pdn-ipv6-call-disallowed
<info>   [modem0/bearer1] verbose call end reason (3,1028): [cm] emm-detached
<info>   [modem0/bearer1] verbose call end reason (3,2001): [cm] no-service
the no-service one happens 3-4 times for each bearer 1,2,3.
Somehow I got a phone call and it all works. Not sure how I got it to work.
And somehow I am back to all calls failing.
Maybe I need to recieve a call to start being able to make a call myself.
  Cannot make calls neithan76 2 445 03-26-2025, 04:55 AM
Last Post: dukla2000
  Firefox does not work on stable version. joe1 1 1,078 06-09-2024, 06:41 PM
Last Post: GaryM
Question Always Use Mobile Data DingDangDoong 4 3,644 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  Cannot send or receive calls insidetrip101 2 2,667 11-04-2022, 06:47 PM
Last Post: mob
  No Application Data PMOS 21.12.1 Captain1ndustry 4 5,471 08-12-2022, 07:42 AM
Last Post: Gon
  Disable mobile data auto-enable on boot 64_Tesseract 3 3,689 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 1,519 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Not receiving messages, microphone doesn't work cosmicschock 5 5,737 12-05-2021, 10:01 PM
Last Post: bcnaz
  Backup user data and settings kratz00 4 6,584 02-28-2021, 03:39 PM
Last Post: kuleszdl
  should charging through the USB hub work? desca 1 3,498 09-17-2020, 02:35 PM
Last Post: desca
