Armbian and LibreELEC and AltLinux for Quartz64
I checked KD5+wayland, it works well. The interface is fast, there are no freezes on the video when moving the mouse cursor, as on x11. Glmark2 showed more than 400 units. test images from KDE5 on the site.
Added EDK2-EFI support for Quartz64-B (directory with extension EDK2-EFI).
As a system with DE, I recommend the KDE5+wayland version. The interface works without brakes. Glmark2 shows more than 370 units. In x11 mode, glmark2 shows 110-120 units.
The installation works on eMMC
Please note, this is a test system and there may be errors in its operation.
LibreELEC version 20230131 kernel 6.1.8
Added LibreELEC support for Quartz64-B.
Use overlays
The order of use.
# mkdir -p /sys/kernel/config/device-tree/overlays/tsys01
# cd <bin directory under DT-Overlays>
# cat tsys01.dtbo > /sys/kernel/config/device-tree/overlays/tsys01/dtbo
remove the dtbo feature:
# rmdir /sys/kernel/config/device-tree/overlays/dtoverlay
https://www.96boards.org/documentation/c...a-configfs
https://github.com/starfive-tech/VisionF...ynamically
Please note, I have not tested this functionality.
Version 20230307 for Soquartz with support for u-boot extlinux.conf. Fixed a problem with the RAM size for models with 8GB of RAM, now all 8 GB are available.
Version 20230307 with core 6.3-rc1 for Quartz64-A and Quartz64-B.
Fixed problem with the definition of RAM, now the full amount of RAM 8 GB is correctly determined.
Soquartz + gnome +glmark2-wayland showed more > 500 units
Version 20230310 kernel 6.3-rc1.
The launch from USB media has been restored.
The Quartz64-A has two USB 2.0 ports (left, upper and lower).
Quartz64-B - the upper USB-2.0 port works.
Version 20230312 for Soquartz with core 6.3-rc1.
Added support to the bootloader for direct launch from USB. All USB-A ports work.
Altlinux 20230314 kernel 6.1.15 for Quartz64-A , Quartz64-B , SOQuartz + SOQuartz Model-A Baseboard
Libreelec 20230314 kermel 6.1.18 for Quartz64-A , Quartz64-B , SOQuartz + SOQuartz Model-A Baseboard
ArmbianTV 20230404 kernel current 6.2.9 and edge 6.3-rc5 for Quartz64-A , Quartz64-B , SOQuartz + SOQuartz Model-A Baseboard
Altlinux 20230404 kernel 6.2.9 for Quartz64-A , Quartz64-B , SOQuartz + SOQuartz Model-A Baseboard
Libreelec 20230404 kermel 6.2.9 for Quartz64-A , Quartz64-B , SOQuartz + SOQuartz Model-A Baseboard
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 5 2,778 01-24-2025, 07:50 PM
  USB on Quartz64 Zero litbulb 0 565 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 33,126 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 61,844 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 2,704 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 2,235 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 2,945 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 7,227 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,972 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 39,639 03-17-2022, 06:29 AM
Last Post: balbes150
