mobile data
I'm on US mobile and had data and mms working but a couple of upates and upgrades later no data connection. Still have phone and sms capabiltiy but no data. I have tried mulitple apns no luck. I flashed Biktorgj's firmware and recovery several times and different versions no luck. Phone shows 4G connection but no data. Wifi and bluetooth work fine. I'm running 2/20/22 weekly no help so went back to unstable still no help.
Curious, did you swap in an activated sim card, or activate the sim card in your pine phone.?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I'm seeing similar symptoms.
Specifically, my problem seems to be DNS.
If I run a command:
curl http://pine64.org
I get an error:
curl: (6) Could not resolve host: pine64.org
But if I try to reach the IP of pine64.org directly:
curl http://91.219.133.83
I get a little success message.
This impacts my ability to use the internet, get/send MMS, etc. Wifi still works (though not for MMS).
Sounds like this bug that's hit Mobian and maybe others. You can downgrade networkmanager or try one of the workarounds listed.
https://gitlab.freedesktop.org/NetworkMa...issues/931
(02-23-2022, 08:05 PM)bcnaz Wrote: Curious,  did you swap in an activated sim card,  or activate the sim card in your pine phone.?
I activated the sim with my pinephone last year when I got it. I had everything working until sometime around the end of Jan or the beginning of Feb.
(02-24-2022, 07:38 AM)wibble Wrote: Sounds like this bug that's hit Mobian and maybe others. You can downgrade networkmanager or try one of the workarounds listed.
Thanks, this was the issue. For me the resolvconf solution did not help, but the networkmanager downgrade did.
Lightbulb pinephone mobile dock jasmin763 2 417 06-06-2022, 09:06 AM
Last Post: 98cwitr
Question Mobile data suddenly gone epiii2 1 281 05-23-2022, 04:57 PM
Last Post: epiii2
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 293 05-21-2022, 03:03 PM
Last Post: zetabeta
  No data access on ATT prepaid but my plan has data dc2daylight 6 1,675 04-03-2022, 02:14 PM
Last Post: dc2daylight
  Mobile case wanted - with wireless charging! thorensjubilee 4 892 03-19-2022, 10:29 AM
Last Post: vap0rtranz
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 457 11-07-2021, 10:15 AM
Last Post: beta-user
  GCI data on Pine Phone nelstomlinson 0 688 09-26-2021, 04:04 PM
Last Post: nelstomlinson
  How did you get data working on PureTalk? nelstomlinson 2 1,354 09-26-2021, 03:50 PM
Question Mobile Carriers 67comet 29 16,263 07-14-2021, 11:47 PM
Last Post: rocket2nfinity
  Intermittent Mobile Data csmgj7 4 1,707 07-13-2021, 03:28 PM
Last Post: Nutmeg
