Jump Drive for the Pine Phone Pro
Is the "Jump Drive" image for the 'Pine phone Pro' available yet ?
I understand the original "Jump Drive"  image is only for the original Pine phone.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
https://github.com/dreemurrs-embedded/Ju.../issues/68
Any News on the "jump drive image" for the Explorer Pro edition ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(02-16-2022, 02:44 AM)bcnaz Wrote: Any News on the "jump drive image"  for the Explorer Pro edition ?
Have you considered installing tow-boot to spi instead of using the normal u-boot? It has fixed suspend/wake for me and when booting and holding volume up, you can put your ppp into mass storage mode and basically replace jump drive with a built in solution. I have to admit, that I have not tried flashing anything via tow-boot mass storage option as of yet, though.
Tow-boot is still kinda new, lets see how it progresses.
The recovery from suspend problem seems "fixed on my original Pine phones", only my Explorer Pro w/Mobian is not recovering.
I currently have Arch/Phosh on my Pro and it recovers almost instantly.
No O.S. I have tried yet on the Pro shows a green boot light ?
Arch uses the vibrate as a boot indicator.... but no boot indicator light.
The phones read speed of the emmc is about 7 times faster than its read speed of the sd cards.
The sd cards are fantastic for test driving, but for performance the emmc is the way to go for longer term use.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I don't understand how works Tow-boot.
How I use Tow-boot ? Do I use it like jumpdrive ?
Can I install an os on my pinephone pro with etcher with Manjaro desktop on my computer ?
(03-25-2022, 09:20 AM)matbos Wrote: Hi,
When you install tow-boot, you have 3 different options upon boot.
1) eMMC - turning on the phone and leaving it along will boot to the OS on the eMMC
2) SD card - when the red light turns on after booting it up, hold the volume down button until the phone buzzes and the LED finishes changing colours (I think it cycles from blue to white or something like that). Let go of the volume down button once the LED stops cycling
3) USB storage - when the red light turns on after booting it up, hold the volume up button for a few seconds and you can connect the PPP to a computer to access the eMMC. You can easily flash a new OS to the eMMC using this method. This is the method you can install a new on the PPP using etcher
There are some YouTube videos that guide you through the process as well, but this is it in a nutshell.
(03-25-2022, 10:35 AM)LPIZ Wrote: 1) eMMC - turning on the phone and leaving it along will boot to the OS on the eMMC
2) Hold volume down, press and hold power button until red led comes on, release power button while continuing to hold volume down until led changes to yellow.
3) Hold volume up, press and hold power button until red led comes on, release power button while continuing to hold volume up until led changes to blue.
(02-16-2022, 06:00 PM)bcnaz Wrote: Tow-boot is still kinda new,  lets see how it progresses.
I installed Tow-Boot to my PPP's SPI, I run Arch from the SD card, and I removed U-Boot and the factory OS volumes from the eMMC. Green boot light seems to work fine for me. Probably because there is no longer any reason to hold the Volume Down button while pressing the Power button (which I believe does return a blue LED and a short vibration, when using Tow-Boot), in order to boot from the SD. Which the phone will default to, with the eMMC wiped. You just hold the Power button for a sec and the phone wakes right up, or powers on, if it was off. This is just "as I understand it to be". If I've mis-stated something here, anyone can please feel free to correct me.
Does tow-boot on SPI eliminate or supersede u-boot on sd card? Should tow-boot on SPI some how fail, what does recovery on the PPP Dev edition entail?
  Phone wont turn on with any SD Card inserted Ausfaller 3 443 07-21-2022, 10:20 AM
Last Post: Ausfaller
  PPP Phone rings with constant vibrate - turn off vibrate henrythemouse 0 202 05-16-2022, 03:59 PM
Last Post: henrythemouse
  Guide to Suitable Phone State Borealid 18 2,609 05-08-2022, 08:46 AM
Last Post: mburns
  Bookworm on Pine phone Pro - Explorer Edition bcnaz 4 1,079 03-20-2022, 04:48 PM
Last Post: fxc
  Portfolio not activating on either phone (PPBeta, PPPro) iwm 5 1,180 02-11-2022, 09:32 PM
Last Post: bcnaz
  Cannot wake the phone after "systemctl suspend" on PPP liberty1234 8 1,398 02-08-2022, 01:06 AM
Last Post: liberty1234
  Making a call in Phone kills PPP phone tckosvic 0 380 02-01-2022, 08:42 PM
Last Post: tckosvic
Question Pine Phone Explorer Edition - Distrohop Boot Issues fssSGJ 5 1,100 01-30-2022, 02:16 AM
Last Post: bcnaz
  Still having problems w. Calls app - Speaker Phone not usable iwm 3 912 01-06-2022, 08:14 PM
Last Post: bcnaz
