Mepo - Minimalist and hackable OSM map viewer for mobile linux
#21
(04-18-2022, 07:52 AM)mil Wrote:
(04-17-2022, 09:37 AM)biketool Wrote: Did you do dev work on Maemo5 apps?  This name looks like an updated app I remember from my N900.
Are you considering distributing via flatpak?
Ah no that must have been something different on Maemo5.
And I would surely support a flatpak for mepo - if someone would want to do the work to create the packaging currently I could help out / guide re-dependencies / build. If not I may look into it myself (depending on demand / user interest).
It would be appreciated if Mepo was available as a flatpak.  I feel like flatpak is a way to get an evened out app experience for most pinephone users across most distros.  Anothe feature I feel is very important, and I am not sure how well Mepo supports it is human readable geo URIs, with these I can reference to a paper map, call it over a radio, or easily SMS or email the location, it also lets me do the reverse importing an approximate location form a map or just receiving a friend's location via IM.
Hi all - Mepo 1.0 has been released, you can read more at the mailing list update at:
https://lists.sr.ht/~mil/mepo-devel/%3C4...ail.com%3E
With the new release, mepo now supports Phosh, Sxmo, and now Plasma Mobile out-of-the-box.
Also since the last update here, note mepo now supports geopositioning (as of 0.5).
Additionally per request a flatpak has been added as well to Flathub so usage on Mobian and other distros is now doable, see:
https://flathub.org/apps/details/com.milesalan.mepo
On postmarketOS edge, to install you can run:
apk add mepo-scripts
See the install guides for other distributions at: http://mepo.milesalan.com/installguide.html
A new documentation website is at: http://mepo.milesalan.com
And demo videos are at: http://mepo.milesalan.com/demos.html
Mepo 1.1 has been released featuring new functionality to transfer pins between groups (e.g. so you can now save and combine multiple search results etc.). As well zenity has been changed to be the only menuing option, and some other features and bugfixes have been incorporated. You can see a preview of changes to the UI at the userguide at:
http://mepo.milesalan.com/userguide.html...e-overview
The release announcement for 1.1 can be seen at:
https://lists.sr.ht/~mil/mepo-devel/%3C3...ail.com%3E
As of 1.1, now you may now install mepo on postmarketOS independent of UI (works for Phosh, Plasma Mobile, Sxmo, Swmo, etc.) by installing the package mepo-scripts.
To install on postmarketOS run:
You can use the Flatpak if on postmarketOS stable, Mobian, or another distro where packaging is not available yet. See the installguide at:
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 975 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,211 10-24-2023, 08:57 AM
Last Post: Peter Gamma
  Proximity lock on Plasma Mobile alpineduck 0 997 08-14-2023, 05:51 PM
Last Post: alpineduck
Information Quick&dirty VPN quick setting button for Plasma Mobile Kevin Kofler 0 1,041 04-06-2023, 02:40 PM
  Arch Linux on PinePhone Rocky-IV 4 9,780 12-21-2022, 04:35 AM
Last Post: gregb49
  Control HBIAS through a linux OS twiclo 0 1,017 10-04-2022, 03:20 PM
Last Post: twiclo
  difference between android and linux? vanja 3 2,125 09-16-2022, 07:43 PM
Last Post: TRS-80
  meet franz! (whatsapp,telegram,etc linux client) vanja 0 1,108 09-15-2022, 01:23 AM
Last Post: vanja
  HowTo: Get a passcode from DUO Mobile working on the Pinephone kop316 2 3,747 01-16-2022, 03:46 PM
Last Post: michel_luc
Bug My experience running desktop Linux on PinePhone Subsentient 5 4,847 12-31-2021, 05:41 PM
Last Post: Subsentient
